RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Please Help with Avalanche Diffs.... (https://www.rcuniverse.com/forum/redcat-racing-support-427/7302772-please-help-avalanche-diffs.html)
Redharris 03-29-2008 07:15 PM
Ok....Im goin through my Buddies Avalanche after his big crash (another post entirely:D) and I am workin on the diffs right now.
The front diff turns (fingers) Smoothly. The rear Diff feels NOTCHY (best way I can describe it), and the center Diff feels better than the Rear (seems TIGHTER) but not as smooth as the front..
This is the first time I will be diving into the Differentials and I have no experience with how they should FEEL.
Should they be Buttery Smooth and FREE (almost loose)?
Should they have some Clicky/Notchy aspect to them?
Or is there some middle ground?
Any advice or Tips would be welcome.......
Thanks in Advance.......
Chubbysdad 03-29-2008 07:33 PM
RE: Please Help with Avalanche Diffs....
they should not be super loose and should not making a big clicking noise. we run 10 in front 30 in center, and 5 or 7 in rear. Just a suggestion
yaris 03-29-2008 07:34 PM
its supposed to be smooth, you can open it and check if the gears are in the correct position and if there is any wear
TThib 03-29-2008 08:40 PM
You may notice little shims... they are supposed to sit flat against the case. (going by memory, forgive me). I pinched one when reassembling the rear diff on my hurricane and it caused a real "notchy grinding feel". I disassembled it and found the pinched shim was causing extra pressure, fixed it and all is good now.
Redharris 03-29-2008 09:30 PM
Thanks Guys.....
That advice helps.....LOL at least now I have some CLUE as to what I am doin......The Mechanical part is no problem for me,,,I just lack any actual EXPERIENCE with these Differentials.
When I am done usin my Buddies Diffs as a learning experience, I will tackle my own Monsoon Diffs:D....
Thats the price he pays for not fixin his own STUFF....Heh,heh.....
