RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   drill start questions (https://www.rcuniverse.com/forum/redcat-racing-support-427/7372741-drill-start-questions.html)
gokartingbob455 04-14-2008 03:13 PM
I''m tired of dealing with the pull start and im gonna get a drill start, but before that i need to ask a question or 2..........or maybe 3, i dunno. when do the drill starters come back in stock? what do i need to get it turning? will a 1/4 inch backplate work on the vertex .16?
thanks, Daniel
dominicevans 04-15-2008 03:31 PM
RE: drill start questions
these are what I use on my vx .18
http://www3.towerhobbies.com/cgi-bin...?&I=LXMVE0&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXAFE9&P=7
gokartingbob455 04-16-2008 03:04 PM
is that all i need? will that back plate fit on the .16?
dominicevans 04-16-2008 03:28 PM
yea thats all you need
but I AM NOT SURE if it would fit..you should ask one of the forum support guys
gokartingbob455 04-16-2008 04:32 PM
ok thanks man......................hey forum support dudes- yo a little help here?
Chubbysdad 04-16-2008 09:08 PM
never used that one so I can't answer. I only used the redcat ones for the vx.18
gokartingbob455 04-16-2008 09:14 PM
well win do the redcat ones come back in stock
can you tell me about those working on the .16 engine, like if i have to get another back plate to fit the back of the .16?
Chubbysdad 04-16-2008 09:16 PM
the vx .16? If so the roto start plate that redcat sells will fit the vx16 and 18. THink I have a few left.
gokartingbob455 04-16-2008 09:19 PM
so......does the roto they sell come with the back plate that will fit? im guessing i have to use some sort of rechargable battery for it. no d batteries im guessing.
dominicevans 04-17-2008 06:32 PM
nope 6 cell battery pack(stick) 7.2v and you would need if a charger
anyways I was out running today after converting the bb to singlespeed and now i can spin all 4 tires in dirt/small stones
lol talk about fun wow
firebird78 04-18-2008 08:37 PM
ORIGINAL: gokartingbob455
I use a cordless drill to start my buggies...I just knocked out the pin on the end of the wand that goes in the drill and it works great...
Cam_132 04-19-2008 02:12 AM
lol MAN i use a cordless drill for my rotostart and it is 750rpm and i found it is not fas enough... i tryed and prove my point... i threw my engine into my vice and tryed to start it with the plactic rotostart part on it... (geared part) and i had no luck... i took it off and had the 1 way bering and got a drill bit that would fit a 6mm hex (one for a rattchet) and it started up right away! so i will be geting the hpi rotostart 2 just wand one...
firebird78 04-20-2008 11:01 AM
I dont know what yall are doing....I use a cheap black and decker drill from walmart to start 2 different sh.28s' and it cranks em over with ease...unless you have some hug engines with alotta compression...
dominicevans 04-20-2008 12:04 PM
no the drill that you are using probably has alot of speed and not as much torque while the other drills have alot of torque but not enough speed to start the engines
