RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Project: Redcat (https://www.rcuniverse.com/forum/redcat-racing-support-427/8224097-project-redcat.html)
jpilkinton 12-08-2008 04:14 AM
Project: Redcat
1 Attachment(s)
This will probably be the last project I do for a while. I couldn't make my mind up if I wanted a nitro crawler or just a high torque monster truck.
The tranny gear ratio is 12:1
I'm not looking for speed on this one. I had to mount the engine up front and backwards to rotate the correct way with using only one counter gear. If I used two counter gears, the ratio would be something like 24:1 and that would be slow enough for a crawler.
I am hoping to get this one done before x-mas.
Enjoy the pics!
el_tonto 12-08-2008 03:11 PM
RE: Project: Redcat
While you've already done most of the engine mounting work - do you reckon you could spin the counter gear around and move the engine forward an inch and a half? Then you can make the cooling head stick out the 'hood' of the bodyshell :D I've always wanted to do that but I've mostly moved to electric stuff now.
You'll need to work around the steering somehow but I reckon you would manage.
AllAboutFunHobbies 12-08-2008 09:50 PM
RE: Project: Redcat
That is fricken sweet. Where on earth do you come up with all these ideas. Awsome man, glad o see all those old tremor parts coming in handy for someone. Bro you must have A.D.D. the way you keep getting all these crazy ideas.
jpilkinton 12-09-2008 04:59 AM
RE: Project: Redcat
ORIGINAL: el_tonto
That would be cool. I believe the head will come through the body where the windshield and the hood meet.
As of now, I don't have much room to play around for steering. I may have to make a linkage and put the servo on the other side of the tranny. And then there is the linkage for the throttle and brake.......hmmmmm....
I'm sure I will find a way to make it all work.
Thanks man.
jpilkinton 12-09-2008 05:08 AM
RE: Project: Redcat
ORIGINAL: AllAboutFunHobbies
Thanks Wade! Coming up with ideas is all I do now. I am constantly running through ideas in my head about what I can do next. Sometimes, it seems like there is no end to it. [:@]
I think after this one, I will take a break(and enjoy the ones I have done) and look into some 1/10 scale parts or some 1/8 scale parts. I do have a spare SH12 engine sitting on a shelf collecting dust. :D
el_tonto 12-09-2008 03:34 PM
RE: Project: Redcat
You could always use a Y-cable and twin servos for any of those functions. e.g. one servo per wheel for steering, and perhaps a mini-servo for the throttle and a regular one for the brake or something. Then the linkages are a piece of cake.
jpilkinton 12-14-2008 10:37 PM
RE: Project: Redcat
ORIGINAL: el_tonto
I may have to end up using a servo for the throttle and one for the brake and another one for steering. (Like you said) :D
jpilkinton 12-14-2008 10:45 PM
RE: Project: Redcat
1 Attachment(s)
OK, here is a follow-up of the project:
I got the front steering assembly in place and I made a set of home-made wheel extensions to get me by while my buddy Rob(@ wheelextensions.com) makes me a custom set for these tremor's axles.
el_tonto 12-15-2008 03:18 PM
RE: Project: Redcat
whoa those are some massive extensions - surely they'd stress the carrier assembly too much? Actually the final photo doesn't look too bad so maybe they'll be ok
jpilkinton 12-16-2008 10:41 AM
RE: Project: Redcat
ORIGINAL: el_tonto
LOL! They are like 1.300" in length. I believe the carriers will be ok since this one won't have any major speed with the gear reduction. If they do show any signs of stress, I may look into some aluminum carriers to replace the stock ones.
jpilkinton 12-19-2008 03:22 AM
RE: Project: Redcat
1 Attachment(s)
Got the body mounted. Just gotta start adding the guts.
jpilkinton 12-19-2008 03:28 AM
RE: Project: Redcat
1 Attachment(s)
Here is a before and after shot:
el_tonto 12-21-2008 03:13 PM
RE: Project: Redcat
Dude you should put a (functional!) [link=http://www.liquidrc.com/index.php?main_page=product_info&products_id=23751 &zenid=n1sdoakn0dseogdf4tqj3f3j04]air scoop[/link] on the hood
bigpurv74 12-21-2008 03:20 PM
RE: Project: Redcat
hey jpilkinton. i have an idea. i think it will work and if it does than yeah it could be a suggestion for hsp for a next vehicle. ok so on ur rock crawler or some other vehicle try getting some oil filled shocks to put on instead of upper liks on the trucks suspension. i think its a good idea because if they are soft/firm they could definitly give more independance on the wheels. just concept ive been thinkin. if ur gowin up a rock it could bend up and grab more traction or if its a truck if could grab dirt better when it is turning or goin up sumthin
if u can, on ur next model try it, i know u normaly do work on 1/16 but if u could try to build a 1/10 or 1/8 truck with this suspension design. hope this works out and could u pm me or sumthin to give me fee back if it will work
jpilkinton 12-21-2008 10:41 PM
RE: Project: Redcat
ORIGINAL: el_tonto
That is cool. I was looking at using some rubber tubing(for air filters) and re-routing the air filter to where it sticks out through the scoop on the body.
jpilkinton 12-21-2008 10:44 PM
RE: Project: Redcat
ORIGINAL: bigpurv74
Yeah, if and when I do my next one, I will go with 1/10 parts. I may buy one of those cheap Exceed beginner's buggies and start chopping away at it.
bigpurv74 12-21-2008 11:53 PM
RE: Project: Redcat
hey thts a good idea on the hood scoop. oh and the exceed buggy is a good choice i have one and the have potential for customizing.
jpilkinton 01-01-2009 09:05 PM
RE: Project: Redcat
OK here's a video of me starting it up and letting it run a fulle tank of fuel:
I just have to make some final adjustments and it will be done.
Part 1:
http://www.youtube.com/watch?v=wcWeMSa2Dgw
Part 2:
http://www.youtube.com/watch?v=kSTU8LbqoQw
rotorlush 01-13-2009 04:48 PM
RE: Project: Redcat
You've inspired my build!:D
