RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   tornado questions (https://www.rcuniverse.com/forum/redcat-racing-support-427/8425223-tornado-questions.html)
clontz_wi64 02-01-2009 12:52 AM
tornado questions
well i'm going with a big block single speed swap setup in my tornado
has anyone found a metal gear for the middle differential to substitute with yet??
i know that will be the first thing to break but oh well i got extras, i know i'll need em' along with some c-cups
and if anyone has done a big block in a tornado let me know what you have ran into doing this
and should a 9.9kg/cm servo be enough to upgrade for the steering/carb?? or should i go a little more around 12kg?
el_tonto 02-01-2009 04:20 PM
RE: tornado questions
The tires determine the steering torque required, the stockers only need a 3kg servo - a 10kg servo should turn monster truck tires with ease. The throttle/brake servo around 6kg would be good for squeezing the brakes with monster tires - if you're using buggy tires then a 3kg servo is plenty.
I've got a Savage spur in my tornado but it's not a direct swap. A couple others on here have put HPI gear in their cars, most require a bit of modding and crossed fingers to get to fit. But there are plenty of metal gear options for the Savage trucks so it's possible.
Do you have the 2-speed or the single-speed?
clontz_wi64 02-01-2009 10:48 PM
ah i see well i have the 2-speed but i'm putting in their 1 speed differential in instead
