RCU Forums
-   Redcat Racing Support (https://www.rcuniverse.com/forum/redcat-racing-support-427/)
-   -   Engine Mounts (https://www.rcuniverse.com/forum/redcat-racing-support-427/9621107-engine-mounts.html)
McWolf_101 03-29-2010 10:57 AM
Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Are the engine mounts that come with the Monsoon XTR compatible with the starter box #70110 or are other engine mounts required? </span></span>
billymare 03-29-2010 11:24 AM
RE: Engine Mounts
As lolng as the flywheel is exposed by an oppening on the chassis, it should work. ( if the box your looking at is a universal type)
Mickstix 03-29-2010 10:40 PM
RE: Engine Mounts
The engine mounts are fine, but the pull starter (and possibly the back plateof the SH .28 motor) are so low, that it requires spacers, which puts the flywheel out of the reach of starter boxes.. I've read about some getting it to work by removing the pull starter, and I think grinding some off the lower ears of the backplate.. Look back through the "Monsoon Support" thread and I think it's in there..
Here's a couple pix.. In the first one you can see how low the backplate is to the frame.. Not sure how much material you can remove before you get to the "backplate" screws, but I know there recessed up from the pull starter screws some.. And in the other one I highlighted the 4 spacers that come on it stock..
http://home.comcast.net/~mickstix/RC...otormount1.jpg
http://home.comcast.net/~mickstix/RC...otormount2.jpg
McWolf_101 03-29-2010 10:44 PM
RE: Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Thanks alot for the replies guys. By the way Mick, how's it going?</span></span>
Mickstix 03-29-2010 11:17 PM
RE: Engine Mounts
Me or the Monsoon?? :D Were both doin good! I've not had the Monsoon out in about a week cause I had to tear it down to put on some mud guards.. I ended up having to completely strip the frame, so I could mark and drill/counter sink the mounting holes for the guards.. So I've been taking my time polishing it up andgetting it back together.. Other than that she runs like a beast! :)
Aint she purrdy! :)
http://home.comcast.net/~mickstix/RC...oon_st-rr2.jpg
McWolf_101 03-29-2010 11:23 PM
RE: Engine Mounts
1 Attachment(s)
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">I'm glad to hear that you and 'The Monsoon Beast' are doing well Mick, and yes, that chassis is a beauty. http://www.rcuniverse.com/forum/js/f...ular_smile.gif By the way, I think I found something but I'm not sure. Does anyone know if these would provide the desired lowering effect that is required to use the starter box?</span></span>
Mickstix 03-29-2010 11:27 PM
RE: Engine Mounts
I dont think the motor mounts are gonna be the problem..(Although if those are for a big block, they'll probably work fine) But the stock motormounts (w/o the spacers) will let ya lower it, but it's the backplate and pull starter that get in the way.. You need a new backplate that doesnt have the starter shaft hole in it, and then ya need to grind on the bottom/back of the engine/backplate, so it can sit down low enough on the chassis to let the starter box get to the flywheel..
McWolf_101 03-29-2010 11:29 PM
RE: Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Ok, I understand. The reason I ask is beacuse I want to switch to an engine that doesn't use a pull start or roto start, so I'll be changing the back plate.</span></span>
Mickstix 03-29-2010 11:30 PM
RE: Engine Mounts
I got ya.. I dont know why the SH .28 is made that way (with the backplate too low) but some other brands of engine will probably work w/o any mods needed.. </p>
McWolf_101 03-29-2010 11:35 PM
RE: Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Alrighty then. Thanks alot Mick. You're always a great help. http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif If all goes well and I FINALLY get my vehicle later this year, I'll let you know how much fun my girlfriend and I are having with it. http://www.rcuniverse.com/forum/js/f...ular_smile.gif</span></span>
UrcHobby 03-30-2010 01:38 AM
RE: Engine Mounts
ORIGINAL: Mickstix
Me or the Monsoon?? :D Were both doin good! I've not had the Monsoon out in about a week cause I had to tear it down to put on some mud guards.. I ended up having to completely strip the frame, so I could mark and drill/counter sink the mounting holes for the guards.. So I've been taking my time polishing it up and getting it back together.. Other than that she runs like a beast! :)
Aint she purrdy! :)
MICK WHAT DID YOU DO!!!!! [X(] EHEHeh That Truck was on one piece when it left here..... :D
Mickstix 03-30-2010 09:57 PM
RE: Engine Mounts
Dont worry, she's all back together today.. :D
http://home.comcast.net/~mickstix/monsoon.jpg
billymare 03-30-2010 10:05 PM
RE: Engine Mounts
Thats a nice ride Mick.....Did you check that place in Deltona?
McWolf_101 03-30-2010 10:16 PM
RE: Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Mick, the Monsoon looks really cool with the dirt guards. Good job man. http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif</span></span>
Mickstix 03-30-2010 11:17 PM
RE: Engine Mounts
Thanks Wolf!! There a tad short (made for a Kyosho ST-RR) but I tried some that were made for the Redcat 1/8buggies and they didnt fit well at all.. These mate up perfectly with the chassis and I couldnt pass em' up since I got em' for a song.. (I bid $3.00 for em' on an ebay auction and actually WON!!) :D
Billy, thanks!!Ithinkit's one of, ifnot THEbest model Redcat makes!!Andyes I went by "The Pit" and checked it out! Looks pretty cool! There was noone there when I went, but I plan to go back sometime on a weekend and see if there's anyone there bashin'!! ;)
McWolf_101 04-01-2010 11:06 PM
RE: Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">I'm going to move slightly off-topic and ask if the receiver battery pack for the Rampage and Dune Runner will also work for the Monsoon? I ask because of the higher mAh rating of the 1/5 scale receiver pack.</span></span>
madmarty 04-02-2010 12:45 PM
RE: Engine Mounts
you can use a sportswork .26 on your sh .28. bolts right up. also, you might have to widen the hole where the bump box wheel engages the fly wheel. i have done this to my older monsoon and i love it. no more one way bearing.
Mickstix 04-02-2010 10:51 PM
RE: Engine Mounts
Good info to have Marty!! Thanks!
Wolf, as long as it's an rx "hump" pack and made with five  2/3A size cells, it'll fit the Monsoon's battery box.. Look on the outer shrink wrap, it should list what size cells are in the pack..
McWolf_101 04-02-2010 11:13 PM
RE: Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Thanks alot Marty for the information on the engine mounts, and Mick for the information on the battery pack. My reason for asking about the receiver pack is related to the connector type, that is, if the receiver pack for the 1/8 scale vehicles has the same type of connector as the 1/5 scale vehicles. </span></span>
Mickstix 04-02-2010 11:24 PM
RE: Engine Mounts
Hmm... Cant help ya there.. I know the Monsoon (and most Redcat's I think)takes a "BEC" type connector.. Hooks the battery upvia the "on/off" switch..(see below)
Note:The Reciever takes a standard "servo" type connector, but the battery hooks to the on/off switch with a BEC connector, then the on/off switch hooks to the reciever with the "servo" style connector.. You could make it work with either, with a little soldering though.. ANyway, below is the BEC connector, that's attached to the battery.
http://home.comcast.net/~mickstix/becf.jpg
McWolf_101 04-02-2010 11:28 PM
RE: Engine Mounts
1 Attachment(s)
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Yea, I've realised that Redcat seems to favour the BEC connector. I'm just not sure if the connector shown in the picture I'll attach IS a BEC connector as well. </span></span>
Mickstix 04-02-2010 11:37 PM
RE: Engine Mounts
Ah, yea I see what ya mean.. Hard to tell from lookin at that? I think it is, but I wouldnt swear to it.. You can always order just a BEC connector "pigtail"and clip the connector from the battery and put on the BEC type, if it comes with a different type? Kurt at URCHobby.com may be able to hook ya up, or I know Tower Hobbies sells em.. The battery takes a "female" BEC connector.. Female BEC pigtail
Note:Also, if you get a Monsoon, the battery holder that comes with it has the BECplug on it, you could scavenge if ya wanted to?
McWolf_101 04-02-2010 11:42 PM
RE: Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Once again, thanks alot Mick. In the end, I may just stick to the 1100mAh receiver pack. I am planning to upgrade the steering servo as soon as I can but I believe that 1100mAh should do the job. Just out of curiosity, what receiver pack do you use, and how long does the charge last?</span></span>
Mickstix 04-02-2010 11:59 PM
RE: Engine Mounts
I use the 1100mAh Hump pack as well, and although I've not timed it, I'd say it lasted about an hour total, the last time I charged it? It's only been charged 2x though, and never trickle charged like it should be, so it might last even longer if I ever get a charger that can charge it properly? At the moment I just use an old "peak" nicd charger I have, and charge it at .5 amps.. Took about a 1/2 hour to peak.. But I've read that you should trickle charge a new pack, for like 11 hours @.1 amps to get it to accept maximum charge? (I dont know a whole lot about batteries, butthe short answer is,it lasts alot longer than the 4 "AA" energizers I started with..) :D
I also upgraded the steering servo.. I got a 208oz. jobber from ebay.. It's fast and strong!Turns those big tires with ease! ;)</p>
McWolf_101 04-03-2010 08:54 AM
RE: Engine Mounts
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">Ok, thanks Mick. I think I'll just use the 1100mAh pack then since that should satisfy my needs. http://www.rcuniverse.com/forum/js/f...ular_smile.gif</span></span>
