Mag 52FS on SPA3DT Question
PA
I know there are/is a thread/threads about somebody running a Magnum 52FS on a SPA3D, but I can't for the life of me find it.
Is anyone running a 4-stroke on the new SPA3DT? If so, what size FS? I am considering either the Mag 52 or an ASP 61FS and would be interested in what prop(s) might work best for these 2 engines.
RE: Mag 52FS on SPA3DT Question
12x4(.52) or 13x4(.61). I'd get a size larger, just in case. If I have a choice, I'd take the .61. It weighs the same as a .40 sized 2 stroke. The props recommended fotr the .61 are 13x4 to 13x7 so I'd try the 14x4 and the 13x4. Ought to be outstanding!
My Feedback: (13)
I had an ASP 61 FS on my SPA3D and ran a 12 x 6 APC on it. I recently put a TT 54 4 Stroke on it just to test the engine. I use a 12 1/4 by 3.75 on it and get equal performance . The TT doesnt make quite the power as the ASP, but it's not hauling the weight either.The plane does handle a little better with the lighter TT 54 though. So I have decided to keep it on. Either way it is a fun plane, just a little more nimble with the lighter engine. I would think that you would get similar results from the Magnum 52 4 stroke.
Prop selection is kind of a trial & error thing. Try what others have used, but also experiment. I was suprised that the 12x6APC turned out to be the ticket for my combo with the ASP. Go figure?
Dwight
Dwight
I've got the Mag .52 4S on my SPA3D and use a MAS 12x6
and it works okay. Currently testing an APC 11x5 and it
seems okay so far.
I've got 5/32 wire main LG on it now and some hollow tube
inside the fuel clunk hose to keep the clunk from getting
jammed inside that little nose on the front/bottom of the tank.
seems okay so far.
