Spad Control horns? Can't find 2.5" PVC
Hello,
I am buidling the SPAD 3D and found everything except the 2.5" PVC, I looked at ACE and all my local hardware stores.
Heck I spend more time in serching for the PVC than building the SPAD 3D
I mainly finished the SPAD 3D, for mounting the wings, stab and fin to the fuse I used metal backings that came for my car speakers.
They worked great.
But if can't find the 2.5" square PVC for the control horns, what else can I use?
I have standart control horns but doubt that they will be suitable for coroplast due to small base area.
They worked great.
FL
RE: Spad Control horns? Can't find 2.5" PVC
Do it best hardware
Here is a link to the product. If they do not have it in stock they can orderit in.
http://doitbest.com/shop/product.asp...292&sku=105736
Here is a map to the one closest to Bethlehem, PA, its 14 miles away in Macungie, PA
http://maps.yahoo.com/dd_result?ed=x...PA&tcountry=us
Hope it helps
Henry
Hope it helps
Henry
IL
Just go to any hardware or home store and get yourself one of those blue electrical outlet boxes. They work great to make control horns. Spad cheap too...
Al
Al
Henry, Al,
I will first try the electric outlet box as I need for only control horns, 10ft is a little too much for that.
I picked up a pvc 10 foot section of rain gutter at home depot for three dollars, will make any of the mounts you want for the rest of the time you are intrested in spads
i didnt even use pvc for the control horns i just used a old lid off a plastic storage container that seems to be tuff as nails and very easy to find. just look around for old lunch boxes and **** like that
ON, CANADA
regular "balsa" plastic control horns work just fine too. Don't be afraid of the small footprint. WIth the plastic back plate, they are A-OK.
