Kraut's mousse can pipe
For Kraut's mousse can pipe on the spadtothebone website, he is using a 1" O.D. thin walled aluminum tube. Where would I find aluminum tubing like this? I really want to build a mousse can pipe for my Thunder Tiger .25GP using this method. Thanks.
CO
RE: Kraut's mousse can pipe
Fortunately someone threw one of those telescoping light bulb removal poles in our dumpster at work. The outer sleeve is a perfect 1" diameter. I made one from a telescoping clothing rack tube but it was mild steel and quite a bit heavier. I had been eyeing the handle on an old fishing net but then along came the dumpster find.
rrh
rrh
TX
I found a shower curtain rod at Wal-Mart to have the 1 inch OD. Well at least the outside section of the 2-part rod. Probably not the most economical but easy to find.
