Spad restlessness
ON, CANADA
RE: Spad restlessness
Good stuff. Now cover the cardboard with some latex EXTERIOR paint (it's fuelproof with a topcoat of hobbypoxy or clearcoat), add the rest of the stuff (engine, etc) and go fly it. Cardboard planes have been around and popular for quite some time.
Same rules apply as for coro, balsa, etc.
If you decided to sell it, you wouldnt even need to pack it for shipping, just put the address on it
I learned to fly back in the late 70's and my first trainer was a kit made from cardboard, glued together with pva like balsa and covered in solar film, flew really well, and looked like all the other trainers once it was finished.
NJ
If you decided to sell it, you wouldn't even need to pack it for shipping, just put the address on it
As far as restlessness, I am just about fed the @#$@ UP with SPAD planes I make that don't fly. I guess I will give it a break until I can figure out what I am doing wrong. Today my DDUST didn't even seem like it had surface. GL.
ON, CANADA
ORIGINAL: RC-FIEND
ROTFLMAO, dude that is funny .....
MT
This plane is nowhere near airworthy! I made it by ducttaping cardboard together and cutting it with preschool scissors. And i didnt even really worry about my measurements, kinda eyeballed everything however i did take off down the road on my bike holding it and it tried to fly kinda, but the ballance point is behind the wing (maybe if i actually had a engine i could fix that :>)
-Fox
-Fox
RC-FIEND, instead of hijacking FightingFox's post start a new thread with some pics of your completed ddust. front, side, top, back etc.
ORIGINAL: FightingFox
NJ
You missed the boat, I did an entire thread on the build for the DDUST . But it doesn't matter I just have to get back in the lab and get it balanced properly.
MT
Good luck RC i hope it flies sometime soon, im waiting for flight reviews and such, looks like a awesome plane.
Thanks jbolt tehe :>
-Fox
-Fox
NJ
Thanks for th encouragement FightingFox, I can give you a quick review :
1. First flight had a dude toss the pane for me it went up and then nosed into the ground . Only thing broken was the engine mount. (wood)
2. Second attempt , I underhand launched the DDust , it went straight up and then nosed down into the ground. only thing broke was the engine mount.
Conclusion : Switched fuel from 15% to 5% nitro , the MAGNUM .28 ran 100% better on my little extra 300 which is demolished for the fourth time , this time do to dumb thumbs. I did not try the engine on the DDUST yet after switching fuel ,but will after finding a stronger engine mount.
ORIGINAL: RC-FIEND
2) You refuse to listen to any of the advice given to you...
3) You dont use the proper materials in some cases, as an example, building a Debut wing out of 4mm coro, which the original plan calls for 2mm and canadian downspout fuselage, and you used 4mm to construct your Ddust, which is obviously a plan made out for 2mm.
ORIGINAL: RC-FIEND
maybe try building a spad trainer or combat plane, easy to get them to fly. i am not good enouf for a dimond dust. to hi of stall speed []
TX
I thought the title of the thread was 'Spad reslessness'. Sounds like a perfect title to express someones design frustrations.
Maybe Agent Mulder didn't realize the X-Files got canceled.
ORIGINAL: FighterBird873
What did I do to deserve such a crappy joke on your part?
NJ
Yea beat it Muldoer you TROLL . How can you go around saying someone hijacked a thread in a forum room you didn't even start ?
As far as me using the wrong materials , Ask CHRIS SPAD himself who told me to use what I can get and improvise. If you have a problem with that, then I will let you sort it out with yourself. [:-]
Thanks FighterBird873 for putting this nobody in his place. Talk about high jacking a thread , he types everything I did wrong , and thinks he giving me the best advice in the WORLD ! go figure
As for those who are trying to help me I appreciate it , the next step I took was to buy a MINI BEE and practice flying with the elevon set up .The BEE is electric and is 34 1/2 inches wide which should help with controlling the wing.
i'd like to see where i told you to improvise. I told you exactly how i built the ddust, and yet you still didn't build it properly.
For the record, i am not involved in this in any way, but, muldoer's points are defenitely valid.
NJ
Chris I am convinced you will disagree with me if I told you I was going to save your life. I guess you don't remember your post about using coro for the fuse instead of pipe. I guess you don't remember making a fit about me not being able to find the darn pvc pipe. You are a hypocrite and I can care less if you agree with that dimwit. Besides I never had a problem building the DDUST , it came in at 2 pounds even after using 4mm , if I even did use 4mm I don't even know how can you ? And to put this to bed he is not right , he's just a brown nosed kid or adult wanting to fit in somewhere. So I guess under your wings will do.
MT
Whoa now ladies, no fighting is my post. Indeed this is for spad restlessness, whatever your case might be. As for RC, yes, improvising can work most of the time, however and full plane out of 4mm when it shouldve been out of 2 mil would have a decent weight difference i would assume. And i think you should lead up to the ddust, maybe make a flying wing first? relitivly the same but i think a wing would be a little easier. your possible problem would be not enough experience to fly one of those? It sounds like it has too much speed for you. Im just guessing, im by far the least experienced. Plus RC i think you should reread your forum, it has good information, and take this plane as a learning exp, and build another better one. Or tweak with this one a while and maybe itll fly. And mulder, maybe you should try to be alittle more polite, wont start arguments as easily thanks for all your posts, and i invite you you argue about whatever it may be you want to argue about, but try to not insult one another? (the x-file joke was rather funny however...hehe) Hope you guys settle this little fued, seems like its been going on for a while!
-Fox
-Fox
NJ
Fox I never said I was going to give up , I said I am fed up . Yea 2mm is lighter than 4mm but by how much ? can't be much if my plane came out the same weight as Chrissy SPAD said it should . So what the hey . I'm not losing a dime attempting to make these plastic toys so maybe I will just post only when I get them to fly like some of the veteran spadders do. This is my entire argument , no one starting out in spad building can get it right 100% of the time but no one post there down falls . So I guess I will join the crowd. NO SWEAT off my back.
RC-FIEND:
I can't understand why you have had so many problems getting a simple airplane (the whole SPAD concept) to fly. It is rather simple to do if you FOLLOW the tried and true plans that are posted on spadtothebone website and build straight from them. Did I have a few problems with my first SPADS....yes and ChrisSpad was one fo the first ones to try and help me out in getting them to fly correct. Turns out the ailerons were dropping a bit (I missed that in the final setup) and that was all I needed to do to solve the problem I was having. Have I experimented with the last few builds....YES but only after I have built several planes from the plans with no mods done to them. I understand that you have to start somewhere but first you must get one to fly before you can start tweaking the design to your liking.
Have I ever gotten a SPAD to fly.....YES I DID! As a matter of fact I flew 2 of them yesterday and have 3 more in my garage that are flyable. Check out the webpage in my sig to see my planes.
I can't understand why you think anyone owes you something when all you do is bash them for trying to help you out. Anyone every told you to respect your elders (even if they are younger than you but have more experience in a specialized field)....I'm guessing not from the response and flame war it looks like you're still fanning.
If it wasn't for the veteran SPAD builders helping out the new guys this would soon become a boring hobby with no growth in ideas for new planes or building methods.
Ok I'll step off the soapbox now
Madd_Maxx
Madd_Maxx
AL
ORIGINAL: RC-FIEND
You probably meant to say out of the ring YOU CLOWN !
Sad to say, the above quote typifies RC-FIENDs reaction to all who try to help. Wonder why he has had such a notable lack of success
jess
