"ML Spattern"
#51
NE
RE: RE:
Here is the video
http://www.youtube.com/watch?v=dITOw5nRGg0
Plane has been been hanging in the basement for a while.
I had to use some of the radio gear in another project/plane.
I would probably use square hardwood dowel stringers along the length of the fuse similar to this.
Once the airframe had a little time on it, it started to loosen up and twist in rolling maneuvers.
That made the plane a little less precise.
If you had to do it all over again, what would you do differently?
#52
NE
RE: RE:
ORIGINAL: JC Fardo
I have some questions, perhaps too late:
1) What are root and tip % thickness in ML Spattern wing.
2) Is that a 1.125'' O.D. wing tube in photo #10
Thanks for comments
JC
Thanks for comments
JC
Wing tube O.D. is 1"
Root spar thickness is 2"
Tip spar thickness is 1.25"
#53
RE: RE:
Thanks Omaha
Is there any link, pics or quick instructions to how to get triple taper and straight trailing edge wing?
BTW nice ML Pattern video on youtube.
Thanks again
JC
Thanks again
JC
