Go Back  RCU Forums > RC Airplanes > S.P.A.D. Aircraft - Coroplast design
Alternative engine mount for spad? >
S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Old 04-19-2003 | 12:07 PM
Default Alternative engine mount for spad?
Hello to all spadders.
I am building my umteenth spad and have now started on a Spad Demon. I am looking for alternatives to purchased engine mounts. Does any one have suggestions for strong alterntive engine mounts????? thanks
Old 04-19-2003 | 12:26 PM
make your own out of hdpe cutting board. Take a look at the qhor for an example.
Old 04-19-2003 | 03:02 PM
Other than those kitchen cutting board... I am using a 1/4 in plywood as engine mounting and it works fine too. Should the plane nose dive crash, the plywood works as the plane crumpling zone. It breaks before it could break the engine and this have infact saved me a lot in reducing major damage to the engine carburator.
Old 04-22-2003 | 09:15 AM
Do a search on the RCCA Spad forum. there are HDPE ones, aluminuim ones, sheet metal ones, basicaly you can use anything
