What to do...
NH
What to do...
I have recently acquired a sheet of yellow 10mm coroplast (24"X32" with the flutes running along the 32" dim.) I also have 4 O.S. engines laying around...a .40FP, .40LA, .46LA, and a .15LA. I was thinking about trying a delta, PBF, or a profile Cub or something. Does anyone have plans, suggestions, or ideas? Thanks for the help! P.S. This is my first attempt at spading! -Craig
CA
RE: What to do...
Hello and welcome to spads. the 10mm is a lot thicker than what we use, 4mm and 2mm are the normal stuff we use. there really are not any plans for a profile plane, and the 10mm wouldbe great for the fusalog. it would also be great for a flat wing, like a foamy plane would have. I would be looking at the foamy plane designs first. there are a lot of them on rcgroups under the foamy scratchbuilt thread. For regular spads and coro education, go to spadtothebone website. there is a ton of info on building with coro and a bunch of free plans. also visit the spadworld site for more info, check out the stickies on the forum, tons of info.
ND
RE: What to do...
I agree with Draftsman. Maybe look at the GeeBee on STTB website. And I made the Tuit out of 2 mm Coro so anything is possible. Just keep looking for what you like and build it. The worst that can happen is you crash and break a prop. OK alot more can happen but be possitive. What ever you make, fly safe and check the balance before you send her to the skies. That is where I find most of my problems on new builds. I don't double and triple check CG before maiden. Good luck and let us know the results.
NH
RE: What to do...
Well, I started a delta. 32" span...40LA powered. I'll have to get some pics for you all. The weight is actually not that bad! See ya soon! -Craig
