S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
SPA3D Question.
Old 06-18-2003 | 11:57 PM
My Feedback: (17)
Default SPA3D Question.
I read somewhere that somebody was actually mounting their engine to the bottom of the cutting board engine mount. Which way works best? I will be installing an enya 40 to a spa3d tonight and I want to make sure it's right. Thanks.
Also on the QHOR with the 36" wing. Is anybody installing stiffners into the wing?
Old 06-19-2003 | 12:37 AM
Look in the QHOR & SPA3D thread.
The QHOR has the engine mounted from below, the SPA3D has it mounted from above.
Old 06-19-2003 | 01:08 AM
Basically, you do it whenever you can, because it's easier, but sometimes something get's in the way.
Old 06-19-2003 | 02:03 AM
The reason given (by Tattoo, I think) for mounting the engine on the bottom of the board is that it can be mounted that way without having to remove the muffler.
Old 06-19-2003 | 02:12 AM
flyboone's Avatar
Either way is fine. It doesn't matter from a thrust line point of view. I'm using carbon fiber stiffeners in my wing, but some others are using music wire.
