Scale Racing Discuss all aspects of semi-scale pylon racing.
Prop Choices
Old 03-21-2018 | 01:51 PM
hossinarizona's Avatar
My Feedback: (22)
Default Prop Choices
I have been playing around with various props on my 7 pound 4 ounce World Models Spitfire, it has a YS FZ115WS running on 30%. I currently have a 13.5 X 13.5 APC turning around 9800 RPM. I am hoping to run in the silver class, and I really don't want to use a higher nitro content to save on glow plugs, and wear and tear on the YS.
Any additional thoughts on prop choices would be greatly appreciated.
Mike
Old 03-21-2018 | 09:35 PM
PLANEBENDER's Avatar
Hi Mike, Everyone will have their opinion however I find when running 20-35% I have best results with your combination a 14X12N is best. You should see 99-10.1 rpm. That airframe likes 10,000 rpm on the ground to maintain good speed in the turns. Just my 2 cents. Hey, what do I know.... lol
Dave
Old 03-22-2018 | 11:27 AM
My Feedback: (22)
Dave
Hi Dave, Thanks for the reply, you said "I have best results with your combination ", but then you said "a 14X12N is best". So is the 14X12N a better choice that the 13.5x13.5 that I am currently using
Old 03-22-2018 | 05:43 PM
Giving the nitro content you are using and the Aircraft choice. Yes.
Old 03-31-2018 | 11:22 AM
cowboy69's Avatar
Default YS newbie
Hi Dave, Dean. reading the previous posts, I am confused about your last response. "Yes", to which propeller, sir., with 30% I am considering jumping the YS hurdle and, like Mike, appreciate any advice. I am also wondering if 30% is absolutely necessary or does 20% suffice without too much performance loss in the 115?
Old 03-31-2018 | 08:06 PM
Cowboy, If SILVER is the class you are preparing for then if using a WM Race series plane and a YS-115 is your engine of choice then 20/20 fuel and a 14X12N will give you more that enough speed and turning ability to easily break out in the Silver class.
Dave
Old 04-01-2018 | 10:06 AM
My Feedback: (66)
Dave is correct 20% nitro is plenty for silver as a WM 46 size warbird with 20% nitro, YS 115 and 14x12N will run 1:45 all day long. I have tried to slow mine down and ran a 16x8 also and still breaks out on 20%. The 13.5x13.5 is to much for anything below 45% IMO.
Old 04-01-2018 | 10:44 AM
cowboy69's Avatar
Default Thanks guys! See you in the air...
Old 04-01-2018 | 01:02 PM
My Feedback: (22)
Thanks for the input, I will try a 14x12N and see what happens.
