RCU Forums
-   Scale Racing (https://www.rcuniverse.com/forum/scale-racing-183/)
-   -   Macchi kits (https://www.rcuniverse.com/forum/scale-racing-183/11600008-macchi-kits.html)
speedracerntrixie 06-07-2014 07:31 AM
Macchi kits
1 Attachment(s)
I'm mulling over the idea of doing a short run of 3 Macchi kits. I'm thinking glass fuse, sheeted foam wings with retract mounts and glass bagged tail section. Anyone interested can PM me for details.
airraptor 06-08-2014 08:10 AM
I have mine being made now. I will shoot for 200 MPH with mine straight and level some 65-75% nitro
speedracerntrixie 06-15-2014 07:48 PM
4 Attachment(s)
I'm just finishing up on Airraptor's Macchi kit now. I documented a few steps of the construction in order to demonstrate the level of fabrication the end user will receive. I also need to publish specs.
wingspan: 62"
length: 54"
wing area: 520 sq in
weight: 6 to 7lb depending on equipment.
The first pictures are of the wing construction. 1 lb white foam with 1/16 sheeting. The spars are 1/8x1/4 balsa that have a glass box and CF caps. Wheel wells are pre done as are the retract mounts. The mounts are a box that ties into the spar. The end user needs only to fabricate a mounting plate to fit the particular retract and then epoxy that plate into the box. The tail section is pre sanded balsa that gets glass bagged.
speedracerntrixie 06-15-2014 07:52 PM
4 Attachment(s)
More wing construction pictures
speedracerntrixie 06-15-2014 07:58 PM
2 Attachment(s)
Finished kit components.
speedracerntrixie 07-19-2014 08:53 AM
1 Attachment(s)
The Macchi is proving to be quite the formidable weapon in warbird racing.
