Lookin for a fuselage to fit the titan!
AZ
RE: Lookin for a fuselage to fit the titan!
Here's the same ship Barracuda posted (Thunder Tiger MD530), but with a civilian scheme. As he noted, it's an easy fit, and quick build. I had the fuselage installed and flying in about 8 hours. The detail work added alot more time... The nice thing about this fuse is that it goes together fast and easy, and makes a great everyday flyer. If you want, you can take the detail to a much higher level. The only drawback for a really detailed build is that there is no room for a cockpit with the R50 mechanics.
AZ
Mine is built on Raptor 50 mechanics....
I flipped the T/R to the correct (left) side of the boom for scale. VERY easy conversion, which I documented in my build thread here: http://www.scalerchelis.com/phpBB2/viewtopic.php?t=7624
Mine is an R50 V2, but the fuselage kit is made for the Titan. I had to cut 7/8" off the boom to fit the V2. Actually it will look more scale with the longer Titan boom.
A couple more pics:
A couple more pics:
AZ
ORIGINAL: soop7667
NICE! But can you do 3D with a Fuse like that?
Seriously, to answer your question, the added weight of the scale fuselage and details makes 3D an unlikely scenario. But, again, that's not what it's for...
TX
ORIGINAL: soop7667
AZ
True... most people look at 3D and just see a totally out of control heli that doesn't look like any real heli they've ever seen. My MD500 gets much more attention than my pod/boom helis.
3D is not easy... trust me, I'm just starting to get comfortable with inverted flight after nearly a year flying. Scale flying is just a different skill, that can be just as challenging to master. Getting the maneuvers down so they're smooth and accurate, even in not so great conditions takes a lot of work.
My favorite compliment is when one of the flyers at the field tells me he did a double take while I was flying, 'cause he looked over and thought it was a full size heli flying.
Hi RodanAZ,
Have read thru your build thread and i'm very impressed with your work! I always enjoyed watching scale r/c helis fly scale and hover in front with all those blinking LED lights! So cool to look at during sundown... Beautiful MD530!
