Styrofoam
Styrofoam
I do not know of a supplier in your area. When I was looking for bulk foam in my area I asked the local Home Depot who supplied them. I was directed to the manufacturer. Fortunately it was local. I had to buy a minimum quantity. It was 2' x 4' x 8'. I could have it cut any way I liked. I think the min quantity was as much a min. dollar figure as much as a material amount.
Ed S
P.S. I purchased it in Kitchener, Ontario. About a four hour drive for you if you get really, really desperate.
Ed S
AK
Foam
Hobby dealers take note....
Many of us have a need for foam in thicknesses greater than two inches. Why not carry this in inventory, and become the "Tower Modeling" of foam?
If you use foam to make LARGE wings, or to make plugs, as I often do, you don't want to glue 2-inch sheets together. It'd be great if we could get a nice source for different types of foam, and thicknesses up to a foot or more.
I like the pink (6 lb density) foam for plugs, but often have a hard time finding it.
Foam
I don't know where "Little Valley" is, but you can get 1 pound EPS (Styrofoam) in any thickness from Thermal Foams of Syracuse.
They make it in billets 4 by 8 feet, and slice any thickness you want.
I once asked what the maximum thickness was that they could cut, and the answer was "about 24 feet" !!!
Check the Yellow Pages...
Joe
Joe
Foam
http://www.thermalfoams.com/indextf.htm
6173 South Bay Road
Cicero, NY 13039
Ph. (315) 699-8734
FAX (315) 699-4969
Joe
6173 South Bay Road
Cicero, NY 13039
Ph. (315) 699-8734
FAX (315) 699-4969
Joe
Styrofoam
I have gotten foam in as large a sheet as 24" X 48" X 96".
Check with insulation companies in your area. They may not stock it but they can get it if you order enough.
The guy I get mine from adds my order to others he gets and when he has enough for a load he places the order and we get the foam. (within a few weeks in most cases)
Good luck
Good luck
ON, CANADA
Foam supplier in Ontario
Hi Ed, could you please provide me with the contact information of the foam supplier you found in Kitcherner, Ontario. live in Toronto.
Norman
Norman
Styrofoam
I think I have seen adds for foam wing cores made to your template. I don't know if this is of any interest to you but if it is I'll look at some back issues and see if I can find it.
tonyc
tonyc
Styrofoam
The February issue of AMA had a building article by Dick Sarpolus. It was for an 80" foam wing plane called the "All American" In the article he gives the numbers for two places that cut foam wings. I will look up the numbers and post them.
tonyc
tonyc
Ideal Foam Weight
The ideal foam weight is zero.
The density of the foam should be as light as possible consistent with the structural function of the foam. The type of Styrofoam needed depends on the type of structure used to provide strength to carry the bending and other loads of the wing. For low aspect ratio wings with thick airfoils and wood skins, beaded foam of one pound per cubic foot density is probably strong enough. In a stressed skin structure, the foam takes the shear loads and resists the buckling forces from the compression side skin. As the aspect ratio increases and the airfoil thickness decreases, either a spar structure must be added or closed cell foam of two or more pounds per cubic foot density must be employed with carbon fiber skins to achieve sufficient strength and stiffness in a stressed skin structure.
Because the size, shape and load carrying requirements vary over a large range and the possible structural types abound, there is no single best choice of foam. The best thing to do is to engineer the structure to know which foam best fits the application.
Styrofoam
Custom foam core cutters;
This form the February issue of AMA
Robins View Productions, Box 68, Stockertown PA. 18083
Tel: 610-746-0106
Dynamic Balsa & Hobby Supply, Box 107, Leonore IL. 61332
Tel; 815-856-2272
www.dbalsa.com
I have no experience with either of them. Just passing along the info.
tonyc
Tel: 610-746-0106
Tel; 815-856-2272
www.dbalsa.com
tonyc
FOAM CUTTING
Hi Guys,
Thanks for the information which you kindly gave!
It is really appreciated.
Again, many thanks to all the contributors.
Regards
Reuben Saliba
Malta (Europe)
Regards
Reuben Saliba
Malta (Europe)
