Feiseler Fi-156 Storch 1/4 Scale CAD
on the flap thing,I found that getting the correct position on the inner and outer stations,then lofting the pivot points and positioning the assembly around the pivots works.
#31
Will have to have a session on the Feiseler Data File to see if I can help answer your questions....???
Wing almost complete, just have the wing tip and underside left to skin, once I've fitted the 2 servos and linkages. Will then mirror the wing on the required centreline and make a start on the fuselage at weekend. CAD starting to get heavy on this assembly, slowing down my laptop. That's the trouble with Solidworks as the model gets heavy.
#33
These are some outlines from a 1/4 scale design by an Italian company, i don't think they are around anymore.
Regards,
Regards,
