scratch designed Ultimate Biplane.
Using an OS .46AXII. Pictures tell the story.
Basic preplanning
cutting the ribs
2x hacksaw blades together to slot out the leading and trailing edges for the 1/16th ribs
first ribs down on a 5mm2 spar
nice joints thanks to the razor saw.
1/16th sheeting
2 1mm ply sandwiched together to make a curved wing joiner
wingjoiner in place
1mm ply sheerwebbing epoxied in over the wing joiner
starting the bottom wing
measuring the servo slots
carving the trailing edge
nice smooth tips
drawing up the HS
HS gluing
drawing up the fuselage plane
1mm aluminium sheet for the carbanes
all the plywood fuselage parts layed out
gluing the doubler on the 2mm balsa sheeting
3mm longerons
dry fit to check progress, looks straight so far
Basic preplanning
cutting the ribs
1/16th sheeting
wingjoiner in place
nice smooth tips
drawing up the HS
HS gluing
3mm longerons
build update
rear turtle deck.
front turtle deak
vertical stab drying
middle wing strut attachment points
710 grams, well on the target weight of 2.2kg
carving the canopy plug
8oz tank fitting
engine fitted, the carby lines up perfectly with the bung
rear turtle deck.
front turtle deak
8oz tank fitting
rear cowling former
start of the cowl front
channeled out top wing for a 1mm plywood seat for the wing affixing screws
elevator control rod in place
apparently i chosen buzz lightyear colours
servo hatch made
contrasting colour schemes
ready for maiden
fuel filler valve fitted. engine runs fine on the ground with it. longer landing gear fitted as well. I messed up the vac forming of the canopy, too hot. There is no plastic in stock so this one is there temporarily.
