Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Rounded loft?
Old 02-24-2004 | 09:33 AM
Default Rounded loft?
Hi everyone!
This is my first post here.
I'm not sure if this question belongs to this forum, if not please direct me to a more suitable place.
My problem is this:
I'm trying to make a solid model, shaped like an airplanes fuselage.
I thought using a loft would be the best solution, but with a loft I get a shape with flat start and ending.
So to get past this, the only way I could come up with was to make the first and last cross-sections extremely small (still flat ends, but not as noticeable).
So does anybody know how to do this better?
I'd really appreciate any suggestions you might have.
I'm using Autodesk Inventor 7.
Old 02-24-2004 | 09:50 AM
Mike James's Avatar
Default RE: Rounded loft?
I usually make very small circular sections with say, a 1/16" diameter at the nose and tail. (assuming they're pointy) Then I loft the larger sections in between. (or "extrude")
Old 02-24-2004 | 12:58 PM
DOes Inventor 7 have a Tarus tool? I'd try that if it did.
