sandwich method ????
I am scratch building this wing,
have rib number 1 as well as number 12 templates only
plans say that the ribs in-between are produced by the
sandwich method.....????
Guys I Need more info. about this method....~
Rgrds
Hisham
PS rib no.12 is smaller than no.1
Rgrds
Hisham
An old system
There should be some sort of alignment dowels or holes noted with each rib. The number 1 and the 12 on the plans ought to indicate where these are at. Sand each rib to shape and drill in the alignment holes into rib 1 and 12 rib for a dowel, there should be some noticible position and washout.
Separate the two again and accurately drill the alignment holes into ten pieces of rough wood. Then laminate them all together again with rib 1 at one end and rib 12 at the other. Carefully sand all ribs to the shape of the larger, then begin to taper them to the smaller. You then result in a full set of tapered ribs. Use a wood rasp or file to cut in the notches for the spars. Kepp them all tightly bound together until finished too.
Wm.
Wm.
AK
Ribs
If you can get a copy of Harry Higley's book, "Master Modeling", there's a nice pictorial on this method there. I think that both Model Airplane News and Tower carry it. (and there are a lot of other tips in that book, as well as Harry Higley's "There Are No Secrets" and "Mostly Mounting".)
