Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Any self designed AND OR plans builders out there? Post pictures!
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 06-21-2004, 11:07 PM
  #101
rcairplanenut
Default RE: Any scratch builders out there? Post pictures!
nice
What do the molds look like?
SGG
Old 06-22-2004, 10:17 PM
  #102
phuffstatler
My Feedback: (20)
phuffstatler's Avatar
Default My little Norvelian Star Cruiser
Well, it's an older one, but here's a little design I did last year, some of you from the 1/2A forum might have seen....
phil in austin
Old 06-23-2004, 12:38 AM
  #103
William Robison
Phil:
Hadn't commented on it before, but I think it's a shame when your transmitter costs ten times what the plane does.
Haw.
Bill.
Old 06-23-2004, 09:07 AM
  #104
phuffstatler
My Feedback: (20)
But it's the only one I have!!!!
Well, no, take that back. I do keep a Futaba 6XAS around as backup and for park flying with my Shock-Flyer.
phil in austin
Old 06-23-2004, 09:48 AM
  #105
acr007
In responswe to Andre,
Andre, Show me more! I really like that Hawk!
_____________________________
Bigger Badder Meaner Faster!
Revver Brotherhood #41
Hwere is my latest scratch build and plan modified to suit IC from electric plus a feew other mods of my design.
ID:	146506   Click image for larger version
Old 06-23-2004, 10:41 AM
  #106
rcairplanenut
Hi Dick,
Do you have a CAD system on your computer?
I do all my designs on CAD anymore, it helps me a lot
SGG
Old 06-23-2004, 12:27 PM
  #107
dicknadine
I do-- but DUH, sure don't know how to use it. am still of the old ruler/compass school. at almost 80 yrears young, its rough to comprehend this new stuff. beginning to figure out photo attachments. besides if I did use one, I still couldn't print it on the desk top printer. also believe my eraser is quick enough. thanks anyhow. dick
Old 07-02-2004, 03:19 AM
  #108
acr007
My first design of my own, but needs to be refined. For a start fuse is to big so will use smaller fuel tank and reduce the fuse by 3/4" to make it more stream lined. I call it simple jet.
ID:	149520   Click image for larger version
Old 07-02-2004, 04:16 AM
  #109
Darrinc
Here is a different way to scratch build. I started with a large foam block and some CAD DWG's that a friend and myself made. I plotted out the top and sideview, then made templates to hotwire the foam, then did all of the contouring by hand.
This will be a plug that I will pull a mold off of and then layup the actual plane.
ID:	149524   Click image for larger version
ID:	149525   Click image for larger version
Old 07-02-2004, 09:44 AM
  #110
dicknadine
I have using foam as a plug for awhile, I then laminated balsa strips. 1st layer length wise, then next 2 layers at 45 degrees and final length wise. its strong and smooth. almost any contour can be fabricated this way. the attached is an original 81" design by a friend and it sure flys good. dick
Old 07-02-2004, 10:10 AM
  #111
Spastic
Spastic's Avatar
here are a couple of my babys, you can see i like profiles, all my designs
ID:	149572   Click image for larger version
ID:	149573   Click image for larger version
Old 07-04-2004, 11:57 AM
  #112
rcairplanenut
I like the twin boom thing
Old 07-04-2004, 12:07 PM
  #113
rcairplanenut
Here are a few more of my designs
SGG
ID:	150147   Click image for larger version
ID:	150148   Click image for larger version
ID:	150149   Click image for larger version
Old 07-08-2004, 06:39 AM
  #114
Darrinc
ORIGINAL: dicknadine
What thickness and what density of balsa are you using? What are adhesive are you using between the layers?
With four layers you could probably use 1/32", 4lb contest balsa up to 35%.
Wow, great idea!!!
Old 07-08-2004, 07:26 AM
  #115
dicknadine
to be honest-- whatever LoneStar furnish's in 1/32 and 1/16. glue is off the shelf Contact Cement, layer on each side of the balsa, you have to be right the 1st time--no giggling the piece around to fit. width depends on the bend radii. no idea of wieght, hasn't been a factor with me. also wet the piece just before applying it to form- helps in sharp bends. will look for a cutout piece/ sample and photo it for you. if weight is a concern, you could make cutouts in it with a hole saw, that is in flat surfaces. yell if you need more info. here is the cabin cowl of my 81" Stout Sky Car. dick
ID:	151485   Click image for larger version
ID:	151486   Click image for larger version
Old 07-08-2004, 07:52 AM
  #116
CL-415
I finished this first one about a year ago from a plan in a French Mag. 6 feet wingspan, Saito .80.
Now started a CL-415 wter bomber that is going to be 94" wingspan powered by two RCV-60SP engine. Will also have operational retracts and will pick up and dump 1 litre of water.
ID:	151497   Click image for larger version
ID:	151498   Click image for larger version
ID:	151499   Click image for larger version
Old 07-08-2004, 02:40 PM
  #117
Darrinc
Thank you. Actually weight is a consern bacause I am building a 42% plane to be powered by a 100cc engine and balance is a issue.
Have you tried just a 0°/45°/0°, or have you only tried by adding the second 45°. I would think with the taper on some of the pieces that I would not need the second 45° since the shape would give me a phantom layer just by its contour. (eg. the rounded turtledeck, the rounded bottom of the fuse past the landing gear plate)
Old 07-08-2004, 07:03 PM
  #118
SCALECRAFT
My Feedback: (13)
SCALECRAFT's Avatar
Heres a project I have to finish one day. Its an 80" 109F/G. It will have a composite fuse, wing, spinner, carbon scale flying 3 blade, composite Hstab and composite accessories.
ID:	151727   Click image for larger version
ID:	151728   Click image for larger version
ID:	151729   Click image for larger version
Old 07-09-2004, 04:17 AM
  #119
Darrinc
SCALECRAFT
All I can say is wow!!! You sure have them props looking good! Everything else too!
What is the 4th pic?
Old 07-09-2004, 02:53 PM
  #120
SCALECRAFT
My Feedback: (13)
SCALECRAFT's Avatar
Darrinc
The forth pic is of the 109 fuse 1/2's from scale cowl seam, back to tail. Its joined now and working on the vstab to fuse section.
Steve
Old 07-10-2004, 01:58 AM
  #121
Darrinc
Thats what I thought, but wasn't sure.
If you are going to make any more of them....
Old 07-12-2004, 10:58 PM
  #122
Gray Beard
My Feedback: (-1)
Last winters project, A 68inch Boeing P-12 came in at 15 pounds. Scratch built from John Tanzer plans, powered with an OS 120 four stroke pumper. Fly's very scale but maybe just A little under powered if you run into A problem. Very nice plane to build but the CG on the plans is WAY off, if you build one be carefull of that!!
Old 07-14-2004, 02:30 PM
  #123
Bobsean
Bobsean's Avatar
Wow! You guys sure come out with some awsome planes!!! Looking good everyone. About a month ago I thought I'd try designing so I went and bought an electric power system and drew some simple plans. Inpspired by the foamie section I went with blue core foam as my building material. I then built the plane and installed the gear and it was a winner! So, next i improved on my design and built a new plane with the same specs but new mods. This plane will maiden today hopefully!!! I know foam is not held highly in a purist mind but it getts the job done fast and light.
-bobsean-
1st 2 are the origonal, 2nd two are the remake...
ID:	153624   Click image for larger version
ID:	153625   Click image for larger version
ID:	153626   Click image for larger version
Old 07-14-2004, 03:01 PM
  #124
William Robison
Sean:
Unlike building from some one else's plans, your airplanes are true scratch builds, don't allow anyone to disparage your efforts.
Doesn't matter what you use, foam, balsa, or even solid lead. You are building, experimenting, and learning, while you are also enjoying doing it.
Keep it up.
Bill.
Old 07-14-2004, 04:32 PM
  #125
AT401B
Maybe someone could give the definitive answer on scratch building.Is it really scratch building if you use someone elses plans?
