Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
CORELDRAW 11 PROBLEMS
Old 10-31-2004 | 03:40 AM
Default CORELDRAW 11 PROBLEMS
Hi,
At the moment I am doing a bit of tracing works using Coreldraw 11. My p/c is quite new and has 115gigs memory and only a quarter of it is used and has a good video card.
Whilst working, the p/c slows down and then get this "out of memory" error. This only happens when using Coreldraw.
Anybody experienced the same problem and if in the affermative how was it resolved?
Thanks in advance to all those that will be able to pitch in on this problem.
Regards
Reuben
Old 10-31-2004 | 10:19 AM
Default RE: CORELDRAW 11 PROBLEMS
You may need to contact Joe way over at www.rcscalebuilder.com as he is a big advocate of Corel Draw! and often logs in under the title of ProfLooney.
Not too many of us forum followers use this software.
Wm.
Old 10-31-2004 | 10:40 AM
goboto's Avatar
It sounds like you need more RAM (Random Access Memmory). It's not to be confused with your 115 Gig storage of the Hard Disk, or Video Card memory. They are all different things and needed for different purposes by your machine.
