Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
 wingloading in a turn or loop? >
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 12-21-2004 | 05:41 PM
Ebola0001's Avatar
Default wingloading in a turn or loop?
how do you figure out how much force the wings will have to soak up in a tight turn or loop? to get some idea if they will fold on the first flight?
Old 12-21-2004 | 06:35 PM
canadagoose's Avatar
Default RE: wingloading in a turn or loop?
If i can remember right, in a really tight turn (90 degree bank) the plane will pull be around 3 g's, in a 60 degree bank about 1.5 g's.
1 g = weight of plane.
Old 12-21-2004 | 10:28 PM
nIgHthAwK17's Avatar
To help with the memory, in a level, i.e. not climbing or decending 60 deg bank turn, the airplane will "feel" 2 g's, or twice its weight. However, as the bank angle approaches 90 deg of bank (for a non-climbing or decending turn), the g's approach infinity, as it would be impossible to attain any portion of the lift vector to counter gravity if it were aligned perfectly with the horizon. Hope this helps..
Old 12-21-2004 | 11:41 PM
Mike James's Avatar
Here you go, posted by Don Stegall, another RCU member...
http://www.rcpro.org/rccalc/GForce.aspx
Sample: 100 mph, and a 100 foot radius turn is 6.72 G's. Interesting, because when you distribute even these "high" loads over the surface of a reasonably-sized wing, they're not that terrifying. I always build with the idea of at least 10 G's, on most planes, and that's not really too extreme.
The recent Dynamic Soaring record of around 262 mph shows that if the circle's radius was about 200 feet, (my guess) then the plane was pulling 23.07 G's. And that's sustained, too, not just momentary. I've heard that severe winch launches can put 30 or 40 G's on these things.
Old 12-22-2004 | 01:39 PM
As Mike James above says, the G load increases with the square of the velocity assuming all other factor remain the same. Remember F=1/2 MV^2 ?
