Basswood vs. Spruce- What's the diff?
AR
Ok I'm on my second scratch building project and I ran into a little problem. I know this probably sounds stupid, but can I substitute spruce main wing spars with basswood? The plans call for spruce but all I could find at BalsaUSA and Lonestar was basswood!
Thanks in advance,
Matt
Thanks in advance,
Matt
basswood vs. spruce
It all depends on what kind and size of plane it is. If it is a .40 or .60 size sport plane, high wing (i.e. cub type) I would not be afraid to at all. I have even used balsa. I have a 14 yr. old .40 size stick type plane that is scratch built with balsa spars and sheer webs half-way out the wing. The spars are 48" long 1/4" square. It is flat one piece no fiberglass in the center section. I fly this plane pretty rough cause it is my punch holes in the sky plane. Just rember KEEP IT LIGHT Cubfan
basswood??
If you have access to a table saw (or know of a friend who does) just go to the local lumber yard and pick out a nice straight grained piece of pine. you may have to look over quite a few boards to find one suitable, but then cut your own spars. I do this all the time for my big birds; pine is nearly as good as spruce and both spruce and pine are stronger than basswood by a slight amount. One note of caution, if you use hardwoods, don't use CA's as the acid in the hardwoods weakens the joint. You can overcome this to a degree by lightly dusting the joint with soda (the kind you use in the kitchen) before using the CA. I prefere the alphatic resins though, especially when working with hardwoods.
Go to this link for a good comparison of Bass Wood, Balsa, Spruce, etc.
I use Bass Wood from Lonestar or Balsa Usa.
Larry
http://www.mentornet.org/balsa.htm#anchor397363
Larry
A good reference book
Read this:
http://www.netexperts.cc/~lambertm/Wood/usdabook.html
A pretty comprehensive resource of wood properties, strength analysis of wooden structures, etc.
Hope this helps,
Boris
Hope this helps,
Boris
