Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Newbe scratch builder help
Old 02-19-2007 | 10:16 PM
Default Newbe scratch builder help
I need a book or web site to help me build my 64" wing P51D. I have a OS 91 surpas II motor, wheels,landing gear,, plans, but the plans do not tell me what type of wood to use where ? I can build anything, but I need to know what I need in wood and where it goes. I also need to match up my motor to a four or three blade prop. Can anyone help me out ?? thanks Pappy[&o]
Old 02-20-2007 | 01:19 PM
Default RE: Newbe scratch builder help
usually plans say somewhere that balsa should be used unless stated otherwise
Old 02-20-2007 | 01:32 PM
carrellh's Avatar
I can only make suggestions based on the three kits I have experience with
Plywood: Firewall, Fuselage Doublers, Formers, Wing Joiners, Servo Trays
Basswood: Main wing spars, servo mounting rails, landing gear blocks
Hardwood (like Maple): Wing bolt blocks, landing gear blocks
Balsa: Everything else
There are always exceptions. My 40 size Corsair uses "hard balsa" wing spars. If you list whose plans you have, maybe someone has built the same plane and can offer first-hand info and lessons learned.
Old 02-20-2007 | 04:23 PM
Hey all, thanks for the info. It will give me a start. Has anyone ever built one out of aluminium ? That would be fun. Not sure about the weight with my motor. I will check on the plan maker and get back with you. Thanks
Old 02-20-2007 | 05:04 PM
Yes some one did build a P51 mustang out of aluminium. I think it was the late 80's or very early 90's some one built a 1/4 or 1/3 scale D model completely out of aluminium. I remember reading about it in a scale master write up. It was silver with red. An impreseive amout of work.
ORIGINAL: pappywolf
ORIGINAL: pappywolf
Check out www.allmetalplane.com
Old 02-26-2007 | 11:12 PM
My Feedback: (9)
Yes I remember that all metal P-51, it was in the mid 1980's like '86 or '87. The guy who was doing it sold kits like the tail plane, left wing etc., etc. However, it was a work in progress and he took a lot of money in pre-orders from people and then guess what? He skipped town with the loot. Either that or he was kidnapped by aliens or some such crap because he was a much sought after individual.
This is not in reply to the post listed, it's in reply to the one above it.
Old 02-27-2007 | 05:55 AM
[>:] Yea , I read something about it a few days ago. To bad. Well, I am going to give it a try. Finding the small tools is a pain right now. It will be done right. I will post pictures as I go. Thanks all Pappywolf
