STOL plans or kit
SD
STOL plans or kit
I am looking for plans or a kit that includes leading edge slats and flaps. I have an urge to build the best STOL plane possible. I would also be interested in using carbon fiber or carbon tubes where possible. I have been tempted to cut leading edge slats out of styrofoam and then fiberglass them, but that seems to defeat the purpose because of excessive weight. Please give me your input. I have been building for many years, but mostly have experience with balsa and plywood. I really like to build light. Thanks in advance.
GA
RE: STOL plans or kit
Check out Andy Lennon
http://en.wikipedia.org/wiki/Andy_Lennon
He did a lot with STOL aerodynamics. Plans, books...I think there is a kit of one of his designs now.
Was a fellow in Minn or Wisc. states offering extruded plastic of CF slats for ten years now, just for the aircraft noted. Had them in a few sizes, but all 36 inches long. Was like $3 per strip as of late 1990's. He used to have a web site to sell off other products also.
Wm.
Wm.
How about Peter Russell's STOL from RCM&E in the early 70s? It was revised and re-published about 10 years later as well. I have the build articles and plans here, even got as far as drafting it in TurboCAD (though unfinished) and built the tail. Nice vintage-looking model, all built-up, 48" for a .25 - 40 FS, flaps & slats as standard.
I suspect that the plans will have been published in the US as well, possibly in RCM?
SD
Thanks everyone for the input. I will look into the "Robin" kit. I actually have the plans from RCM, but the slats are so small that building them with my fat fingers would be a real challenge. I will look into the carbon fiber slats.
You should try to get Peter Russells articles on his STOL because he explains different ways of making slots/slats.
The P. Russell STOL plan should be avail from Magicalia the new owners of RCME etc at www.modelflying.co.uk. Plan no is RC1445. You should order a copy of the article too- its extra cost.
The P. Russell STOL Mark2 plan no is RC1445. The original plan (mark 1 I suppose ) was RC1190.
I recall that a later article said there was an error in the plan- the flap bellcranks were shown handed but should operate in the same direction, unlike ailerons.
The Pete Russell STOL was published also by Model Airplane News in the 1970's but is no longer listed.
The MK2 STOL was in RCME October 1983 and had a stronger wing with ailerons. I believe this article actually gave the wrong ( mark 1 )plan number and my previous info was correct.
