Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Panel Lines Ryan Sta
Old 06-18-2008 | 06:55 PM
Default Panel Lines Ryan Sta
Hey guys! I'm looking for advice on realistic looking panel lins on my Ryan Sta build. It has a metal skin on the fuse only. Any suggestions would be graetly appreciated.
Thanks!
Richard
_____________________________
Keep on building!
Old 06-18-2008 | 07:13 PM
All Day Dan's Avatar
Default RE: Panel Lines Ryan Sta
I sent you a PM. Dan
Old 06-18-2008 | 08:29 PM
My Feedback: (60)
I built up spot putty against electrical tape to form the overlapped panel lines on my Texan.
Old 06-19-2008 | 12:41 PM
WacoNut's Avatar
Richard,
From the pics that I have of the Ryan it looks like the aluminum panles on the Ryan are butt joints and do not overlap. To simulate this I put down 1/32" or 1/16" chart/drafting tape. Once you have the tape in place where you want the panel lines spray a couple heay coats of high fill primer such as Dupli-Color high fill primer then sand the primer down to the top of the tape and remove the tape. This will leave you a very nice panel line, add rivet details and paint.
I have done this on several planes with great results.
Anthony
Old 06-19-2008 | 02:23 PM
Richard,
Do you have any pics of your Ryan? What size is it? I have the 1/4 scale plans supposed to be on the way from MAN but have not received them yet. Ordered almost a month ago.
Jim
Old 06-19-2008 | 03:58 PM
Hey Jim, Let me know how the plans are. I want to order the 1/3 scale. I have no pictures yet, I'm building the Ryan Sta Special from the now discontinued Sig kit. But I want a bigger one. Where are you going to get the Pants and cowl from?
Richard
Old 06-19-2008 | 04:01 PM
Waconut. I have tons of pictures and documents and they show overlapping joints. Any ideas on the best method of building that?
Richard
Old 06-19-2008 | 05:59 PM
WacoNut's Avatar
The one Chad showed on his T6 will work good, you can also use high fill primer instead.
Anthony
Old 09-27-2008 | 04:17 PM
Chad - can you give me more details on how you formed those panel lines and rivits? I am building a Hostetler Cessna 150 which I am glassing and want to include panel line and reivet detail.
Joe
