double gull wing biplane
TX
RE: double gull wing biplane
The wood is cut and stacked,the family stuff is over,work still bouncing from day's and night's{got the guy trained he got stupid got fired},car repair on going,weather better,repairs on flying planes almost done,and now some more done on gullwing.
#31
TX
here's an up date base covering done, horns on, engine mounted, servo tray ready to install.to do list
1 redesign cowl
2 fuel tank
3 servo tray
4 connect and adjust all linkages
5 checker board bottom of wings
6 come up with a design for top of wings
7 get polit
8 try and get a week end off
1 redesign cowl
2 fuel tank
3 servo tray
7 get polit
#32
TX
Here are some stats on the plane. Engine Supertiger 2300, prop 18X6,raido system spektrum DX6I reciver AR500. each wing 30" wing span 64.25".Fuselage 52" prop to tip of rudder 65.25". Two spekum A6010 on elevator and two on aileron's. An HS645MG on rudder and a hs300 on throttel. first cowl didn't clear carb or muffler trying to build a Waco type cowl.
#34
Interesting concept. What is the idea behind the double gull wing design? (aerodynamics?)
Let us know how she flies...
Good luck
Bundu
Good luck
Bundu
#38
TX
today was a wash out. got her to the field and silly me I hadn't checked the cg sence early in the build oops tail heavy. also the rods that connect the uper and lower ails were to long I made them longer in a BF moment .
Bundubuster I started to build a sunray but decited what the heck why not do two gull wings.
AmishWardLord the cosl is painted.
