Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Hughes H-1 1/4 scale
Old 05-03-2015, 06:23 AM
  #226
coyote216
coyote216's Avatar
split flaps progress. First some masking tape to apply the varnish.
ID:	2093692   Click image for larger version
Old 05-03-2015, 06:37 AM
  #227
coyote216
coyote216's Avatar
then glued the 1mm ply strip
ID:	2093695   Click image for larger version
Old 05-03-2015, 06:42 AM
  #228
coyote216
coyote216's Avatar
next thing to do was to put the triangles..
ID:	2093697   Click image for larger version
Old 05-03-2015, 06:48 AM
  #229
coyote216
coyote216's Avatar
finally the split flaps where ready to take their place ..
ID:	2094054   Click image for larger version
Old 05-03-2015, 06:54 AM
  #230
coyote216
coyote216's Avatar
now the only thing left for the wing was some aluminum at the center section and the markings
ID:	2094056   Click image for larger version
Old 05-03-2015, 06:57 AM
  #231
coyote216
coyote216's Avatar
For the markings I only have one photo for the moment but there are more to come
Old 05-05-2015, 08:53 PM
  #232
BMatthews
BMatthews's Avatar
One of my favorite subjects. If the model appreciates the commitment you've given it the first flight and hundreds more to come after that will all be stunning.
Old 05-08-2015, 08:37 AM
  #233
coyote216
coyote216's Avatar
Thank you BMatthews I really appreciate it.
I must say it is almost six years and it has been a journey but there is still, some distance to cover.
At the moment she stood on her feet the feelings where overwhelming and it did feel like a commitment.
Kir.
Old 06-15-2015, 10:11 AM
  #234
coyote216
coyote216's Avatar
Yesterday the plane stood on the runway for the first time. It was really exciting. The reason was to run some tests and not the maiden.
First impressions were really good except from the wheels that need replacement cause the current ones which are inflatable wont do the job.
So maybe I'll keep these for static display and use some other wheels for taxing. Here some pics from the field.
Old 06-15-2015, 10:15 AM
  #235
coyote216
coyote216's Avatar
Old 01-23-2016, 06:30 AM
  #236
Dmpanhead
I just found this post after talking to my son about how someday I would love to build a large H-1. Absolutely beautiful job. Incredible amount of work. So what has happened? No posts since 6/15. Has it flown?
Old 01-24-2016, 01:19 PM
  #237
coyote216
coyote216's Avatar
Hi Dmpanhead , the plane hasn't flown yet because after the first tests at the field, there was an issue with the balloon wheels. It seems that because they are inflatable, there
was a lot of wobbling during taxiing.So I had to order new ones. But at that time it was difficult to order anything with the capital controls and other issues. Anyway I finally
got to order the new wheels and I recently received them. So I hope that soon enough I would be able to move on and keep you posted about everything.
Here are the wheels.
Kiriakos
Old 01-24-2016, 01:42 PM
  #238
coyote216
coyote216's Avatar
And here is one with the Racer under the stars and one with yours truly
Name:	Racer under the stars.jpg
ID:	2143197   Click image for larger version
Name:	Me and the Racer.jpg
Old 02-07-2016, 09:57 AM
  #239
coyote216
coyote216's Avatar
Did some work with the wheels and now I'm ready for the next field test. Here are the parts that I made -except the screws -
Name:	H-1 Racer-11.jpg
Old 02-07-2016, 10:00 AM
  #240
coyote216
coyote216's Avatar
The wheel mounted on the strut.
Name:	H-1 Racer-4.jpg
Old 02-07-2016, 10:05 AM
  #241
coyote216
coyote216's Avatar
The only way to secure the axle was to drill and tap a hole to tighten the axle with a screw and some Loctite.
Name:	H-1 Racer-5.jpg
ID:	2145824   Click image for larger version
Name:	H-1 Racer-7.jpg
ID:	2145825   Click image for larger version
Name:	H-1 Racer-9.jpg
Old 02-07-2016, 10:09 AM
  #242
coyote216
coyote216's Avatar
And while waiting for the weather to clear a bit I added some flashed rivets
Name:	H-1 Racer-16.jpg
ID:	2145827   Click image for larger version
Name:	H-1 Racer-20.jpg
ID:	2145828   Click image for larger version
Name:	H-1 Racer-21.jpg
ID:	2145829   Click image for larger version
Name:	H-1 Racer-25.jpg
ID:	2145830   Click image for larger version
Name:	H-1 Racer-27.jpg
Old 03-26-2016, 04:54 AM
  #243
coyote216
coyote216's Avatar
The Racer had its second visit to airfield for engine break in and ground tests.
Here are some results.
RPM: 6400 Prop Menz 24/8
Static thrust: 15-16Kg
Range Check: >50m
Taxiing test: very nice handling on the ground though some minor wheel alignment adjustments are needed.
Back to the workshop for that and I think after that, the maiden is near.
Here are some pics of the racer at the field.
Old 03-26-2016, 05:00 AM
  #244
coyote216
coyote216's Avatar
ID:	2154249   Click image for larger version
ID:	2154255   Click image for larger version
ID:	2154256   Click image for larger version
Old 03-26-2016, 05:18 AM
  #245
coyote216
coyote216's Avatar
and a sort Video of the taxiing test
https://www.youtube.com/watch?v=XXT4-OW0RlA
Old 03-30-2016, 03:35 PM
  #246
BMatthews
BMatthews's Avatar
That's looking positively fantastic ! ! ! I'm already looking forward to the flying video.
Old 05-11-2016, 08:22 AM
  #247
coyote216
coyote216's Avatar
Thanks BMatthews I'll keep you posted.
A very basic element was missing so I did some work adding a cockpit to the plane..
ID:	2162000   Click image for larger version
ID:	2162001   Click image for larger version
ID:	2162002   Click image for larger version
ID:	2162003   Click image for larger version
ID:	2162004   Click image for larger version
ID:	2162005   Click image for larger version
ID:	2162006   Click image for larger version
Old 07-18-2017, 08:59 AM
  #248
coyote216
coyote216's Avatar
Hi everyone. I'm happy to inform you that finely last Saturday it was time for the maiden flight with a success.
The Racer is rock steady but maybe a bit nose heavy. But this is something to fix. I will post some pictures and hopefully some time soon a video also.
ID:	2224930   Click image for larger version
ID:	2224931   Click image for larger version
Old 07-18-2017, 09:01 AM
  #249
coyote216
coyote216's Avatar
ID:	2224922   Click image for larger version
ID:	2224923   Click image for larger version
Old 07-18-2017, 09:10 AM
  #250
coyote216
coyote216's Avatar
ID:	2224933   Click image for larger version
