Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Hughes H-1 1/4 scale
Old 11-10-2012, 09:00 AM
  #151
coyote216
coyote216's Avatar
Default RE: Hughes H-1 1/4 scale
that's the stage of the project at the moment
The engine with teh cowl...
ID:	1819099   Click image for larger version
Old 11-10-2012, 09:05 AM
  #152
coyote216
coyote216's Avatar
The hard part of the retracts has come I 'll try to ceep it as scale as possible
but I know it's not going to be easy.
ID:	1819101   Click image for larger version
Old 11-10-2012, 09:07 AM
  #153
coyote216
coyote216's Avatar
ID:	1819103   Click image for larger version
Old 12-25-2012, 07:45 AM
  #154
coyote216
coyote216's Avatar
Hello everyone
I would like to wish you all a very merry christmas and give you my best best wishes.
I hope you all had a very good year and to have a better next one.
Happy landings
Kiriakos!
Old 12-25-2012, 08:00 AM
  #155
RAMFlyer
My Feedback: (65)
Kiriakos My best wishes to you and your family for a Merry Christmas and a Happy New Year!!!
Bill
Old 12-29-2012, 03:21 AM
  #156
coyote216
coyote216's Avatar
Hey Bill
Nice to hear from you. Hope you are ok.
I was wondering if you build that H-1 from Ziroli plans
Kiriakos
Old 02-01-2013, 07:31 AM
  #157
coyote216
coyote216's Avatar
Hello everyone,
It was time for the engines break in, so I made a nice stand from an old coffee table a glow driver
to drop the 12v from a car battery to 1.2v for the glow plugs and we where ready
Old 02-01-2013, 07:34 AM
  #158
coyote216
coyote216's Avatar
And here's a vid from the break in
http://www.youtube.com/watch?v=kA1bUHtarwY
Old 02-03-2013, 08:37 AM
  #159
Sukhoi_Madness
Sukhoi_Madness's Avatar
The engine looks and sounds great.
Old 06-21-2013, 11:13 AM
  #160
coyote216
coyote216's Avatar
Hello everyone
the progress is a bit slow but there is some.
As I'm trying to figure it out with the retracts I started the aluminum covering. starting from the tail section it proved to be very
difficult. Anyway first thing to do was to photocopy the plan and then cut the panels with a scissor and mark them on the fuselage.
Then I used masking tape for the outline of the panel. After that I used a slightly bigger piece of adhesive aluminum foil to fill in
and cutted the rest aluminum with a razor
Some pics
ID:	1893840   Click image for larger version
Old 06-21-2013, 11:14 AM
  #161
coyote216
coyote216's Avatar
Old 06-21-2013, 11:22 AM
  #162
coyote216
coyote216's Avatar
Old 06-21-2013, 11:28 AM
  #163
coyote216
coyote216's Avatar
The elevator and rudder are also in place
ID:	1893845   Click image for larger version
Old 06-21-2013, 03:34 PM
  #164
ARUP
Nice airplane project!
Old 10-21-2013, 12:00 PM
  #165
coyote216
coyote216's Avatar
The time for the retracts has come.
After taking some things under consideration and with the help of a fellow modeler with great experience we decided
that the undercarriage will be the eurocit air spring activated giant units for safety reasons. The strats are going to be
made out of 5mm thick aluminum cutted to shape of the real thing
Old 10-21-2013, 12:17 PM
  #166
coyote216
coyote216's Avatar
The next thing to do was to make the reinforcements for the retract units.
So I applied 80gr fiberglass with epoxy resin
v
Old 10-21-2013, 12:21 PM
  #167
coyote216
coyote216's Avatar
After that I laminated the balsa airfoil with 4mm ply
Old 10-21-2013, 12:30 PM
  #168
coyote216
coyote216's Avatar
using the trial and error method I configured the position of the units.
Old 10-21-2013, 12:36 PM
  #169
coyote216
coyote216's Avatar
Here is a test fit before I glue the base for the units
Old 10-21-2013, 12:40 PM
  #170
coyote216
coyote216's Avatar
Meanwhile the split flaps and ailerons are ready
Old 10-21-2013, 12:48 PM
  #171
coyote216
coyote216's Avatar
Some progress with the fuselage is also made
Old 10-24-2013, 11:38 AM
  #172
coyote216
coyote216's Avatar
Hi everyone
does anybody know how to polish the aluminum tape?
Old 10-26-2013, 02:41 AM
  #173
perttime
perttime's Avatar
Tim Hooper did an aluminum tape covered biplane some time ago:
http://www.modelflying.co.uk/forums/...p?th=56199&p=6
I think his build is probably on some other sites too.
He mentions using a product called Brasso: https://en.wikipedia.org/wiki/Brasso
Old 11-18-2013, 12:58 PM
  #174
coyote216
coyote216's Avatar
Thanks a lot for the tip. To tell you the truth at first back at the store there were 2 products side by side Brasso and Silvo.
For some reason I chose silvo at first with not so good results.I hope that this will do the job.
Old 11-18-2013, 01:11 PM
  #175
coyote216
coyote216's Avatar
As for the progress the landing gears are almost ready here is a test fit to see how she stands
ID:	1949807   Click image for larger version
