Go Back  RCU Forums > RC Airplanes > Seaplanes
Waterproof switch cover? >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 07-29-2003 | 01:59 AM
Default Waterproof switch cover?
Guys, does anyone know where you can buy rubber covers for over your switch. I have some from some old Airtronics with a metal plate that holds it tight against the switch but I need more of them. I am using JR now and these are totally waterproof. I hope somebody still makes something that will work. Thanks in advance.
Old 07-29-2003 | 02:40 AM
sometimes we make spoon shields. if ya wanna try it, you just cut the end off of the round part of the spoon and ca it over the switch. jeff
Old 07-29-2003 | 11:56 AM
First, apply silicone sealant around the edges of the switch / charge jack. Second, apply Vaseline to the switch itself and / or the moving door of the charging jack. Inspect switch after every flying session. Has worked for me for over a year.
Old 07-29-2003 | 12:14 PM
BillHarris's Avatar
Or get one of the Dubro switch holder assemblies. The switch is operated via a 1/16" wire and is not exposed to the soggy outside.
--Bill
Old 07-29-2003 | 06:36 PM
JimCasey's Avatar
Tower lists several:
http://www2.towerhobbies.com/cgi-bin...L=++&search=Go
Maybe that will help.
Personally, I prefer to mount the switch internally and use a wire through a snug hole to actuate the switch.
Old 07-30-2003 | 01:13 AM
Thanks for the input everyone!
