ACE Seamaster 40 ARF Assembly
TX
I purchased a new Seamaster ARF. Is there anything I should know before I assemble the plane? I read that one fellow glued a foam block in the nose cap to keep from losing it in the water. How about the engine mast? Is it strong enough mounting it per instructions?
AK
RE: ACE Seamaster 40 ARF Assembly
I have a seamaster, it has a mecoa .46 and is a great float plane.
Make sure that you get a good glue joint on all the tail parts. I used auto emblem glue to glue down the elevator pushrod.
Back to the spin thing , I let a freind fly mine and he got it in a spin about 3 mistakes high , it continued all the way to the water. ripped the wing off!
everthing floated fine( without the floam ), I had the plane back in the air two days later.
my engine mast is a little loose in the socket , I will end up glueing it in place. After all its not like I'll be taking it off.
Great plane, smooth as silk in the air
good luck!!!
good luck!!!
I can't remember for sure but someone said to put some down-thrust on your engine mount. I think it was 3%. I also permanently attached the tip floats with some Goop adhesive. The engine pod is plenty strong. I wouldn't glue it in as the throttle servo wire runs down through the mast into the fuse. Hopefully someone will correct me about the down-thrust if I got it wrong. I did a search and couldn't find anything about it.
I permanently attached my throttle servo as I don't trust servo tape and couldn't see any other way to do it, more Goop.
Bill
Bill
I would hold off on that down thrust until after it has been flown. I fly a kit version of the Seamaster, and I found that, due to the high thrustline, mine flies better with some UP thrust.
I too permanently attached the floats. They are designed to come off for land flying, but personally, I like the way they look, and I really like flying it off it's belly from grass!
You can see me doing just that in the "Evolution Trainer System" engine review in RCU Magazine.
Maybe it was up-thrust, like I said, I wasn't sure. I'll have a look at mine later today and see if I can tell for sure without taking the pod off. Whatever it was I did it and it flies great.
Bill
Bill
