Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Float Size?
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Float Size?
Old 11-03-2003, 10:16 PM
chewy
Default Float Size?
Alright guys, I'm sure it's been discussed before but , I wasn't into float planes and I'm sure I didn't see it. I plan on trying my hand at float flying in the near future. I just built a new house on a 60 acre lake. I was thinking about getting a Seamaster but have decided that I would rather have a plane with floats. I have a plane called a Perfection kitted by Max Blose out of Waco, TX. It's similar to an Ugly Stik. I've had the plane for over 7 years and just got Max to cut me a new kit. I want to build the new kit with the ability to fit it with floats. Can anyone give me the basic rundown on floats as far as size, mounting location, etc...? The plane has a wingspan around 60" and I'll be using an O.S. 91 4-Stroke. Thanks for any input. Matt
Old 11-04-2003, 08:40 AM
JimCasey
JimCasey's Avatar
Default RE: Float Size?
Float length: 75-80% of the length of the plane from the prop washer to the rudder hinge line.
Alternate rule: nose of float is 1/3 of prop diameter in front of the prop. Step under the 40% Chord point. Step is in the center of the float.
Step of float: under the 40% Mean Aerodynamic Chord point.
Hang the floats a little nose-down (3-5 degrees) so the wing will be able to make lift while the float is running horizontal along the surface of the water. (Top of float level-Wing at 3-5 degrees positive incidence)
Prop arc should clear top of float by 2".
Track of float: 25% of wingspan
Mount the floats rigidly. 2 aluminum landing gears and spreader rods between work very nicely.
Water rudder(s): should hang down no farther than the depth of the step.
Balance the plane in the same place that it would balance with wheels.
You don't need more engine, but dropping the prop pitch an inch is sometimes good. (use 11-5 instead of 10-6)
Mount your switch internally using a pushrod to actuate it.
Don't mount any of the electronics either at the top or the bottom of the fuselage....any water can slosh around without dunking the circuit boards, even if the airplane is inverted.
Seal the inside of the fuselage with a coat of dope/paint whatever to protect the wood.
Use styrofoam floats instead of hollow floats. Hollow floats are good for storing water.
We're here to help. You're gonna have fun.
Old 11-04-2003, 09:54 AM
chewy
Thanks Jim. Lots of good info. Keep it coming guys!! Matt
Old 11-04-2003, 11:44 AM
jrf
My Feedback: (551)
Chuck Cunningham's definitive articles on float design and setup are posted on the RCM website. www.RCMmagazine.com Look under "Requested Articles".
Jim
Old 11-04-2003, 07:08 PM
chewy
Unfortunately I'm not a subscriber to RCM. It won't let me gain access to the site.
Old 11-04-2003, 07:41 PM
JimCasey
JimCasey's Avatar
The Chuck Cunningham article is here:
http://www.flyinglindy.homestead.com/skisandfloats.html
Old 11-05-2003, 11:30 AM
Goinstraightup
My Feedback: (26)
Goinstraightup's Avatar
The above posts are great and also you may want to consider tethering your engine to something solid in the fuse (like the landing gear block) with a steel fishing leader. I was at a float fly and a guys wings folded and the fuse went in the drink pretty hard. The engine went to the bot of the lake. I have it on video and the guy gave the video to divers, but they still never found the engine.
Old 11-06-2003, 12:15 AM
chewy
Good idea. I'll have to remember that one. Matt
Old 11-06-2003, 04:54 AM
Jimmbbo
Jimmbbo's Avatar
Default RE: Float Size - GP J3 ARF?
Have the .40 GP ARF J-3 Cub, and was thinking that using the .60 size GP floats would be a good thing since I will likely fly the airplane on some relatively rough water at the local lake... Will this work? Any "issues" I should be aware of? Thanks in advance for any thoughts.
Cheers!
Jim
Old 11-06-2003, 07:15 AM
seaplane
seaplane's Avatar
Jim, the 40 size would be better even in the rough water. The 60 size would look way too big, 34" vs 42".............Seaplane
Old 11-07-2003, 12:29 AM
Smoky
Smoky's Avatar
LOL watch for the waves! if they get too big! and you hook a float in one while landing, it flips you over pretty quick! LOL Esperience talking. 2 ft is too high, 1 foot is too high. and possible 8 inches is too high of wave. didin't measure the last one, but sure made me bounce! LOL darn wake borders!
Smoky.
PS on float tips. make sure you seal any exposed servo's IE flaps, ailerons. I use vaseline to seal the joint and gear extrusion for the control horn.
