Alternating landing lights question
SK, CANADA
I am putting landing lights on my Unionville T Beaver, as I am installing the winglets anyway.
I have seen these ,turn on, with the either the gear or the flaps. I intend to use the gear channel.
However In the day time when the big planes are landing these lights flash, Alternating
between the port and starboard sides.
Anyone know how to make the lights on the model flash like that? It makes the plane more visible in the day time. and I don't intend to fly at night anyway. LOL
I tried a search but, came up empty. found some lights but came up empty on the flashing part.
thanks.
Smoky.
thanks.
Smoky.
RE: Alternating landing lights question
The full scale equipment you're asking about is called "PULSELIGHT". They pulse because the human eye is more prone to see a blinking light over a steady light. makes it much easier to see oncoming traffic
HTH
Tom
HTH
Tom
BC, CANADA
Smoky I put lights on my T-Beaver.. I used High intensity white LED's for the landing lights and red and green for the wing tips.... Put a high intese flashing red one for the beacon on top of the fuse, but I forgot the one in the tail...oops...
As far as a mak ing the alternating flashing landing lights you could try an electronics store (place that sells IC's, printed circuit boards, LEDs. ect).. My dad (the old guy)was an electronic geek[sm=wink.gif] and he made an alternating flashing light for my train set when I was a weee lad...The guys at the store might be able to help you, I remember the flashing unit my dad made was about 1"X1" and had about 5 parts to it ( an IC,resistors,capacitor ) and ran on 6V....Parts would cost (I guessing) around $10...
If you can't make one let me know, and I will talk to the old guy... I'll see if he'll bring his soldering iron out of retirement....
SK, CANADA
Thanks guys. I'll see what I can find for a Pulselight generator. I like the IDea of using the LED's. If nothing else? then I could use a diagram from you CF_drg so I can biuld my own, since I am pretty handy with a soldering iron. I'll let you all know How I make out.
Smoky.
Smoky.
My Feedback: (23)
Try these guys. They make several alternating LED systems, or look under "Railroad" stuff for what they call ditch lights.
http://www.ramrcandramtrack.com/
ON, CANADA
I actually just ordered my lighting system. Its the Curtek Lighting system from www.zebrahobby.ca (quick service!). This system has 3 flashing navigation, 2 landing lights, and 4 extra connections for any other lights. The landing lights are controlled by the reciever too. Seems like a good system..might make a good starting point for you.
I am interesting in what you end up using for you alternating lights. Please let us all know how it works out.
cf-drg, what system did you use? Are there navigation lights in the tail - I was unaware there were (I can't see it on pictures). Please let me know! Thanks!
Dave
Dave
Banned
use a 555 timer chip
easy to do and will drive either high intensity LEDs or even some globes if you run the o/p via tranny for increased current flow
do a search on 555 applications or go to radio shack as they will have little p[ocket books on the subject.
cheers
Peter
cheers
Peter
WI
Yes, Curtek Lighting system's ROCK! Plus great service and fast delivery. I set them up on my Bell 222 to turn on with the throttle.
Joe
Joe
SK, CANADA
ORIGINAL: pettit
Rick.
