Go Back  RCU Forums > RC Airplanes > Seaplanes
 Pilot Lake Bucceneer >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 01-11-2004 | 09:09 AM
Default Pilot Lake Bucceneer
Hello,
Has anyone had experience of flying these planes. I'm nearly at the stage of finishing and want have any feedback with regard to initial set-up of the model.
The plane has a tractor engine position with a 25 2 stroke fitted. For first flights I will go with the recommended C of G and engine thrust line ( alot of up thrust, I assume as the motor is high above the airframe).
Would appreciate any imput as to whether these settings/engine size should be OK.
Dave
