Seaplane Antennae Routing
Greetings all,
I'm building my second seaplane which is the Aero-Phibian from Hobby People. If you are not familiar with the aircraft, it is a sleek looking, high wing, 4-channel with a combo float/landing gear setup.
On all of my aircraft, I route the antennae thru the fuselage via an Ernst Antenna Guide and exit it out the bottom near the tail feathers. I did the same on the Aero-Phibian as I am setting it up initially for land use.
I did a test mount of the included floats and realized that about 3" of my antennae will be dangling in the water. I double checked the setup of my Lanier Mariner and found the antennae routed out the top of the fuse and stretched out to the top of the tail fin.
Do you think that this small bit of antennae coming in contact with the water will present a problem?
Thanks to all in advance for your time and effort...
RE: Seaplane Antennae Routing
Thanks Mike,
Good tip for everybody. It's amazing how water will find a way to creep into everything on a float plane. On my Lanier Mariner, all gaps, screw heads, hatches, wing saddle, everything is sealed with silicon rubber. All pushrods are filled with vaseline.
Found a great way to seal hatches and wing saddles that you probably already know. Apply a bead of silicon rubber along the wing saddle or hatch opening. Lay a piece of saran wrap over it. Fasten down the wing or hatch. Let the silicon rubber cure, remove the wing or hatch and the saran wrap. Trim the excess silicon rubber off and you will be left with a nice tight seal that will keep out a majority of the water.
Thanks again,
Thanks again,
