Go Back  RCU Forums > RC Airplanes > Seaplanes
 Seamaster Question >
Seamaster Question
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Seamaster Question
Old 04-29-2004 | 06:08 PM
Default Seamaster Question
What should I do to my seamaster to keep water out other than use rubber silicone between the wing and wing saddle. After that I think everything is set to go for the madien flight!! =D I'll try and get some pics, she wont be going up exactly right away though
~Matt
Old 04-29-2004 | 07:07 PM
MinnFlyer's Avatar
Default RE: Seamaster Question
I like to smear some Vaseline in the pushrod tubes to keep water from wicking in, and wrap the reciever and battery in a baggie, but that's about it
Old 04-29-2004 | 08:58 PM
iflyj3's Avatar
My Feedback: (7)
ORIGINAL: Flightfreak777
~Matt
I put a crumpled paper towel inside the fuselage to absorb any water if it gets in.
I also wrap the receiver in a condom, non-lubricated no reservoir tip.
My SM was leaking through the wheel mount tubes.
