Go Back  RCU Forums > RC Airplanes > Seaplanes
 Float Step & CG, Just how far back can it be ? >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 04-15-2005 | 06:55 PM
Default Float Step & CG, Just how far back can it be ?
Just how far back is acceptable for the step to be behind the CG ??
Thanks in advance for any help.
Old 04-15-2005 | 09:53 PM
JimCasey's Avatar
Default RE: Float Step & CG, Just how far back can it be ?
The farther back the step is, the more difficult it will be for you to rotate for takeoff.
There's not a magic number where if you exceed xx% you won't fly ever, but if you're in front of it you'll be fine.
Also, if your step is aft but you rig the nose of the plane a little high, you have a better shot at getting away with it.
All that said, I would be very suspicious of any setup with the step aft of the 50% of chord line.
Old 04-21-2005 | 09:00 PM
Mustang Fever's Avatar
Just finished and flew a Heinkel 31 on floats. Before I relocated the floats forward so that the steps are about 1/4" in front of the CG, it would not come up on plane. Now, it pops up in about 10 feet. (2.5 pound model with a Magnum 15) There's more to it than just step vs CG, but having the CG slightly aft of the steps is one way to easily avoid problems.
Old 04-22-2005 | 07:06 AM
MinnFlyer's Avatar
Rule of thumb - Don't go more than 1/2" behind CG
Old 04-23-2005 | 03:03 AM
My Feedback: (72)
Ditto on what MinnFlyer said, also, the nose of the floats should be in front of the prop buy at least 2".
