Go Back  RCU Forums > RC Airplanes > Seaplanes
 Engine Selection for Seamaster >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 06-19-2005 | 01:13 PM
My Feedback: (55)
Default Engine Selection for Seamaster
I have been flying RC for a little more than 30 years but this will be my first float plane. I selected the Seamaster because of the many positive comments that I read in this forum. I have an engine choice (1) OS Max 46 FX or (2) Super Tiger 51. In the past I have swapped these two choices back and forth in the same airplane and found that the Super Tiger really does have a significant power advantage. My question is whether the added power of the Super Tiger is an advantage for water takeoffs -- in the air I am sure either engine will do the job just fine.
Any and all feedback would be appreciated.
Howard
Old 06-20-2005 | 02:34 PM
ronwc's Avatar
My Feedback: (404)
Default RE: Engine Selection for Seamaster
Really either engine would do the job - I use a Enya 45 CX (11x6 APC) in mine and it has no problem getting off the water or flying - a great airplane and design all the way around -
Old 06-20-2005 | 03:12 PM
iflyj3's Avatar
My Feedback: (7)
I have the OS 46 FX on mine and it does fine.
Old 07-11-2005 | 08:19 PM
Wanted to change out my TT Pro-46 with a four stroke. Do we think that a TT 54S will suffice?? Am of the view that an OS 70 Surpass will be too much.
Any feedback or experience??
Thanks.....
Old 07-12-2005 | 06:36 AM
Howard, engine choice depends upon you & what you like to do with the plane. The Seamaster will fly well with as little power as an OS .46 LA, & I have seen Seamasters with 70 size 4-strokes.
A pod-mounted engine has some disadvantages & one of them is significant mass above the aerodynamic center. More power doesn't always result in better flying (as an experienced modeller, you already know this). A good 46 size engine works beautifully with the Seamaster (TT .46 Pro, for example) and an OS 50SX will provide even more power without a penalty in stability that comes with excess weight.
