Go Back  RCU Forums > RC Airplanes > Seaplanes
 need source for steerable nose wheel block >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 07-26-2005 | 10:50 AM
Default need source for steerable nose wheel block
I use steerable nose wheel blocks to secure floats. So far I've been able to scrounge them up from friends and swap meets - but now these sources have dried up. Anyone know where I can obtain these without having to buy the whole nose wheel unit?
Old 07-26-2005 | 03:18 PM
seaplane's Avatar
Default RE: need source for steerable nose wheel block
I buy them in bulk from SIG. That reminds me I have to order some........Seaplane
Old 07-26-2005 | 04:41 PM
jrf
My Feedback: (551)
Dubro sells them also and you might check Great Planes hardware as well.
Jim
Old 07-27-2005 | 02:09 PM
Thank you gentelmen for your help. I found them on both the SIG and Dubro web sites, although my LHS assured me that they were not availalable seperately. They make great float fittings in conjuction with aluminum arrow shaft spreader bars. The arrow shafts are cut to the desired length and fitted with the standard 6x32 screw inserts at both ends. A 6x32 bolt is then driven in from the outside through the nose wheel block- aluminum u/c - into the arrow shaft. Simple firm and neat. The float track can also be adjusted, by fitting spacers if necessary.
Old 07-30-2005 | 06:22 PM
Try calling Du-Bro direct for your mounts, I'll bet they have them seperate. 800-848 9411. ENJOY !!! RED
Old 07-31-2005 | 08:30 AM
scale only 4 me's Avatar
My Feedback: (158)
Take you choice
http://www2.towerhobbies.com/cgi-bin...p?&C=QDZ&V=GBG
