Go Back  RCU Forums > RC Airplanes > Seaplanes
 Ace Seamaster 40 question >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 02-14-2006 | 07:13 AM
Leemata's Avatar
Default Ace Seamaster 40 question
I am building a Seamaster 40 from one of the old Ace R/C kits. I need to know what the material of the cowl, pod & bow front is so I can be sure the paint I'm using is compatable. Any help would be greatly appreciated.
Terry
Old 02-14-2006 | 11:00 AM
MinnFlyer's Avatar
Default RE: Ace Seamaster 40 question
It's ABS Plastic
Old 03-16-2006 | 10:59 PM
Chip_Mull's Avatar
Call Stan's Fibertech and get the fiberglass replacement parts. IF you don't order it now, you will shortly.
Old 03-17-2006 | 08:26 AM
----or you can fabricate it from balsa -- not diffiucult
Old 03-17-2006 | 07:48 PM
JimCasey's Avatar
And don't use the tank fairing for a handle when you are carrying the plane to launch it.
