Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
LT-40 on floats landing gear
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 04-27-2006, 03:23 PM
jester125
Default LT-40 on floats landing gear
About a year ago maybe less someone had posted some pics of an LT-40 on floats with what looked like bent aluminum straps to attach the floats, not the typical landing gear wire. I was wondering if someone remembers who it was so I could get more info so I can build some for myself.
Thanks, Chris
Old 04-27-2006, 04:05 PM
aenigma
Default RE: LT-40 on floats landing gear
Check out the thread on the first page labeled "Will it fly? (LT-40 on floats).Here is the link:
http://www.rcuniverse.com/forum/m_4116430/tm.htm
Old 04-28-2006, 03:58 AM
seaplane
seaplane's Avatar
Chris, I've attached a drawing of the aluminum struts I made for my wife's LT-40 and a couple pics of a friend's plane. The are 1/8" X 1" aluminum I bought at Home Depot. Hope this helps.
Seaplane
ID:	452029   Click image for larger version
ID:	452030   Click image for larger version
Old 04-28-2006, 11:03 AM
jester125
Thanks guys, Seaplane do you happen to have the measurements for the areas I marked in yellow?
Thanks again Chris
Old 04-28-2006, 05:05 PM
bralex
Chris,
Here are a few pics of the gear/float set up on my Kadet. Let me know if you have any questions!
Old 04-28-2006, 05:11 PM
bralex
Chris,
I seem to be having some trouble downloading the pics. Let try again?
Old 04-28-2006, 08:10 PM
seaplane
seaplane's Avatar
Check your e-mail. I sent you the dimensions you requested. Here they are in case the e-mail didn't work. The strut length from the fuse to the float is 7 1/2" and the spreader is 19".
Seaplane
Old 04-29-2006, 09:05 PM
LT-40
LT-40's Avatar
Hi, the LT-40 in the picture with the yellow arrows is mine. I have the measurements for the aluminum landing gear that I got from seaplane. I used the 1" by 1/8" stuff, but if you want to save some weight and money, use the 3/4" by 1/8". The 3/4" stuff should have more than enough strength. You should be able to find it at Home Depot, thats where I got mine.
File Type: jpg
Old 04-29-2006, 09:14 PM
LT-40
LT-40's Avatar
I don't think my attachment loaded right, I'll just give the measurements. The first yellow arrow from the plane to the float is 7.5", and the long spreader bar is 19". Also, the part that attaches to the plane is 3.5" wide, and the "feet" that attach to the floats are 2"
Old 04-29-2006, 10:27 PM
bralex
Chris,
Finally got the pics to load properly. Thanks Mark! Let me know if you have any questions.
ID:	452821   Click image for larger version
ID:	452822   Click image for larger version
Old 04-30-2006, 10:44 AM
jester125
Awesome pics/details, just what I needed.
Thanks guys!
Chris
Old 04-30-2006, 01:29 PM
seaplane
seaplane's Avatar
Chris, I finally got my JPG's to attach. Go back up to my original post, they are there now......................Seaplane
Old 04-30-2006, 02:08 PM
jester125
Thanks again,I'll definitely use those!
Chris
