Seamaster engine pod
I am getting slightly damagesdSeamaster from another fellow modeller, this plane needs engine pod as it does have pod stand but not the pod itself, i like to know if anyone can provide me these parts or pictures or plans from where i can make pod from scratch myself. I also noticed that the model's nose cone is damaged too, like to know if that is plastic piece or wooden framed up nose...
Sammy
Sammy
MI
Good Morning --- I have scratch built a twin fuselage Seamaster and the nose is a plastic piece but I glued a few thick pieces of balsa together and shaped it to suit. As long as you have the pod mast you are in good shape. I purchased two round 8 ounce fuel tanks. I measured the diameter and went out and purchased four of the cheapest shampoo bottles that were slightly larger than the fuel tank diameter and longer than the fuel tank. I cut off the neck of all the bottles and used the top half of one bottle to form a cowling for the engine and fashioned the other to cover and hide the fuel tank. I made the " firewall " out of 1/4 ply and made it round to just fit inside the shampoo bottle opening. I think I had enough room in front of the firewall to mount a small throttle servo and ran the servo wires down the mast. I am almost certain I did not add any right or down thrust to the firewall. The picture I am sending is a bit too small to show any detail but I think you will get the idea.
Those are probably better pods than supplied with the seamaster.
Did you reinfoce them so they would not be damaged when domeone uses them for a handle to lift your plane?
I once made an engine cowl from a polyethylene iced tea pitcher. It lasted for YEARS. MUCH less expensive than a custom fiberglass cowl, probably lighter and more durable too. And it looked just fine.
VT
ORIGINAL: flynfish44
Ihave a kit built Seamaster and did some repairs on the cowl/pod this past summer and was wondering what I could do if the whole pod /cowl needed replacing, your solution solves my problem. Thanks for sharing, excellent idea. Wish they would produce the kit version of the Seamaster again.
Excellent job on the twin seamaster flynfish44! Thanks as well for the information. I've been attempting to duplicate my own seamaster and I too needed a solution for an engine pod. I also thought of building it balsa with two sides and a platform for the fuel tank.
What engines are you running in your twin fuse seamaster?
MI
The twin seamaster had two Super Tiger 40's which were perfect for the plane. The plane had some bad characteristics ( more than likely it was the pilot and not the plane ) so I decided to make one seamaster out of it with another standing in the corner waiting its turn. Of course I had to build an entire new wing and redo the tail feathers.
