Go Back  RCU Forums > RC Airplanes > Seaplanes
Falcon 40 arf >
Falcon 40 arf
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Falcon 40 arf
Old 02-05-2003 | 11:23 PM
Default Falcon 40 arf
Will get a 46 to 60 size float plane shortly. Would a 50 size OS SX fit into cowl of the plastic Falcon without too much cuttig? Anyone care to suggest a good rugged float plane for this engine?
Old 02-06-2003 | 12:32 AM
FALCON 40
I have one,and they are designed around a Magnum engine & muffler. So if you use a OS, you will have to use a Mag. muffler. It should bolt right up. Other wise you will have to cut more of the cowl than you would like. Other wise good plane.
art43
