Which Saito for a Neptune?
MI
I decided to order a Neptune to give my Cessna 182 float plane some companionship. I have two motors available to put in it....Saito 62 or Saito 72. Any thoughts on which one might be the better choice. Have read through the threads and have seen comments about prop clearance and overpowering concerns. Or is this 6 of one and half dozen of another? Also, any build tips I should be aware of. Thanks for any input.
Jerry
Jerry
MI
RE: Which Saito for a Neptune?
Is the Saito 4 stroke not a good choice for the Neptune?...I am open to other options. I am flying at a lake and I don't want to upset my neighbors so I typically use 4 strokes because of this.
ORIGINAL: MinnFlyer
Given that choice I would pick the 72
I have had a Sea Monster which is about the same size and have flown a friend's Seamaster, the same plane as the Neptune, and a Saito .56 is not the engine for it. On the Monster, I had both a Saito .72 and a Magnum .70 4-stroke and both pulled the plane well. I did use a 3-blade prop for the most part. The friend's Seamaster has a TT .46 in it and that's about the right size, not over powered, but good power. I have had a Saito .56 on a Sky Raider Mach I that was gioven to me that I converted to floats. It putt-putted along OK, but it was a trainer. The Neptune needs a good .46 or the Saito .72.
The Neptune is very close to a SeaMaster so you can more than likely only run an 11" prop, so which engine likes 11" props the best. Other than that a 4 stroke should work just fine.
My Feedback: (35)
MN
I just finished putting together a Neptune with an old Magnum .61 fourstorke. I haven't maidened her yet, but I have a magnum .70 I'll put on if it's not enough power. By the way, the pylon is long enough that you can use a 13" prop without any problem.
Dave
Dave
