Go Back  RCU Forums > RC Airplanes > Seaplanes
 Nextar on Floats >
Nextar on Floats
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Nextar on Floats
Old 08-03-2007 | 05:00 PM
Default Nextar on Floats
I built a nextar with Floats and loved my set up, the only problem is that plane got stolen from my garage. I had installed GALLEGGIANTI
FLOATS, but my problem now is I can't find another set of these floats. I guess they went out of business?? Does anyone know where I can get another set or a different set of floats that will work good with this plane. It has the tricycle landing gears and the galleggianiti's worked perfect. Any help would be greatly appreciated.
Thanks, Kevin
Old 08-03-2007 | 05:57 PM
JimCasey's Avatar
Default RE: Nextar on Floats
here ya go.
http://www.hobbypeople.net/prdcls/floats01.asp
I trust you put out an email to all the clubs in MI and N Ohio to be on the watch for your plane?
jrf
My Feedback: (551)
Those are Modelfly floats from www.hobbypeople.net They are probably the best 40-60 size floats you can buy today.
FYI, "GALLEGGIANTI" is Italian for "floats".
Jim
Old 08-04-2007 | 05:05 PM
My Feedback: (13)
I used some Goldberg Superfloats for mine,my NEXTAR had been crashed a few times so I did a rebuild/rework and recover job on the fuse.
I also went ahead and junked the stock LG for some Great planes gear,just a little surgery was needed,balanced out perfect with a OS 61AX for power.
ID:	735727   Click image for larger version
