Avistar on floats
Avistar on floats
I'm going to make some floats for my avistar and i'm just wondering if [link=http://www.seminolerc.com/EZ-Float-Design.html]this[/link] is a plan to go off of,
Austin
Austin
RE: Avistar on floats
yep. this is the definitive article for building and sizing floats. If you make your floats according to this, they will work.
I like to make mine wider at the bottom and narrower at the top(tapered sides), but that's just me. Chuck built and designed a lot of floatplanes and flying boats.
Ok, got them done today, They mount with zip ties (plastic ties), i used 2 for each gear! the main part of the floats is made with foam and i have two wood strips on the side for extra strength, the rod that the nose gear is mounted on is a light alluminum dowel, and the back dowel is woode just to reduce flexibility. It's covered with duct tape, i wasn't going for pretty with these floats, just functionability,
Ok, so here are some of the specs:
length-34"
width of float itself-3.5" 4 at top
total width-20"
heigth at step-2 7/8" right after step-2" end-1 1/4"
step is about 1" back from cg
I have to add some weight to the end of the floats in order to achive proper cg, so with the weight i have to add the plane will weighs 6lbs exactly without fuel
What do you guys think, Is she airworthy
length-34"
total width-20"
