Go Back  RCU Forums > RC Airplanes > Seaplanes
 Another neptune >
Another neptune
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Another neptune
Old 02-15-2008 | 01:06 AM
Default Another neptune
Hey ive got a neptune with a 52 on it....The plane uses up about 80ft of water to take off, but then seems to fly ok (climbs a bit with power)
Im not sure if the motor is too tired or if ive got a thrust line/cg problem.
Any opinions to my excess runway prob ????
Old 02-15-2008 | 07:16 AM
JimCasey's Avatar
Default RE: Another neptune
80 feet doesn't sound too bad.
Climbing under power could be thrustline or nose-heavy. How much forward stick does it take to fly inverted?
The 30-degree dive test does not work that well for seaplanes since a high-mounted windmilling prop causes a lot of drag up high, and pulls the nose up.
