Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
S6-B
Old 09-27-2002 | 03:32 PM
Default Supermarine S6B
Hi all. Is anyone making a Supermarine S6B seaplane kit, or ARF?
Old 09-28-2002 | 12:50 AM
Siskiyouline's Avatar
Default S6-B
To my knowledge no one is currently producing one. I have been looking for a set of plans that are no longer published from Model Airplane News. The plans were for a S6-B .19 sized engine. I have posts on many of the R-C forums but have had no luck so far in finding a set. I was sent a set of plans for a S-5, also a .19 size. Sam was gracious enough to send them to me and allowed me to make a copy of them. If you come across anything let me know and I will do the same for you..
Thanks!!
Bud
Old 09-30-2002 | 11:28 AM
Default Found one!
I was wrong - Sea - Commander r/c makes a large scale S6-B for Quadra 50-75 engines. It also has a price tag to match, but looks like a nice bird. Here is the link -
http://www.seacommander.com/kits.asp
I found this on another forum and thought that I would pass it on.
Now if I could just find one in a .40 - .60 size------
Bud
Old 10-01-2002 | 09:00 AM
Thanks Bud!
Yes, if only someone would produce a kit in the .60 size. I'll keep looking too...
Old 10-01-2002 | 09:10 AM
Hey Bud. Check out the S6B at Conachen Aviation:
http://www.conachenaircraft.com/S6B.html
Any information on this one?
Kevin
Old 10-08-2002 | 02:19 AM
Default S6-B
Don't know anything about the plane. It looks similar to the Seacommander plane though.
Old 12-11-2002 | 02:51 PM
Check out the following URL:
http://www.conachenaircraft.com/index.html
Jim produces some very fine aircraft. I ordered a Supermarine S6B kit and should have it in a few weeks. I won't be working on it right away as I am also taking delivery on a 170" PBY ARF. I am going to be very busy for the next few months! [img]i/expressions/face-icon-small-wink.gif[/img]
Old 12-11-2002 | 02:57 PM
Boy do I feel foolish!! [img]i/expressions/face-icon-small-blush.gif[/img]
I replied to Kevin F without reading the most recent posts! Sorry to give out duplicate info.
Regards,
Greg Sundt
Old 03-28-2003 | 06:29 PM
My Feedback: (74)
Default S6-B
Model Airplane News August 1969 Supermarine S-6B by Dave Ramsey Max .19 Can send copy if you want. My e mail address;[email protected]
Old 04-19-2003 | 01:29 PM
Default S6-B
Hi Co-pilot
I scratch build electric float planes. I would like to make my next project a Supermarine S6B. Your .19 size sounds like the right size I’m looking for. Can you send me any info. I have built the Herr Aqua Star, 2 Big Stick types from my own drawings and am working on a Norseman with a 63” W.S. All these are electric. The S6B would be a great addition.
Thanks;
Bill
Old 04-21-2003 | 02:48 AM
Default S6-B
Hi Bill!
I have the article that Co-pilot has. He was kind enough to send it to me. The plans that he was talking about are no longer available from MAN. I tried to get them from them but they said they don't have them anymore. The article has a set of plans enclosed. I was able to have them blown-up to the original size from the article. I have both the article that I can scan and send to you, I can send you a copy of the original article in the mail, or if your interested I can have another set of the plans made and send them to you for about 10 - 15 dollars depending on copy cost and shipping.
There are no specs included in the article. After having the plans blown-up the wingspan is about 42" and a finished weight of around 2 pounds. It also has an engine rating of .10 to .23 and states that the larger engine size is more than enough. This article was done in 1969 and the author was using an O.S. 19. Plans also include the patterns to build the floats.
I also have a set of S-5 plans form RCM that is the same size as the S6-B.
Let me know!!
Bud
Old 04-21-2003 | 10:32 AM
Default S6-B
Hi Bud;
I sent you an e-mail with my particulars. Thanks for all the help. I will keep you posted as to my progress. I plan on scaling to 50+ inches. As I do everything electric I will outfit the S6B with a brushless motor possibly geared 2:1. I am presently working on a Unionville Kit of the Norseman which is the other end of the float plane spectrum – slow and sedate. At the moment it is about 60% complete. Hope to have it on the water in May.
Again, thanks for everything;
Bill
Old 04-23-2003 | 04:30 PM
My Feedback: (74)
Default S6-B
Hi Bill I see by the seaplane forum RCAIRPORT that Budd is helping you with S-6B plans.I have had several requests for this and other plans since joining RCAIRPORT. IF AND WHEN you do build it , I would like to be posted on results. My brother built the Cleveland kit about 1938 or 1939. It is not very big, 16 , 18 inch wing span. HE DID a flawless job even a pilot and foot petals and stick that worked the controls rudder ,ail, and el. Good Luck-----COPILOT
Old 07-11-2003 | 06:10 PM
Default S6-B
Mick B. - you emailed me and I have tried to reply but I keep getting bounced back from the address that you gave me. If you need more info than what is here, please retry with your correct address.
Thanks!!
Bud
